04-07-2021, 11:27 PM | #1 |
Spare tire mounting bar
Any one got a photo of the spare tire mounting bar? The one that goes under the rear of a 1965 Suburban.
04-15-2021, 11:49 PM | #2 |
Re: Spare tire mounting bar
Still looking for photos of the under frame spare mounting bar and hardware.
04-16-2021, 01:07 AM | #3 |
Is it different than the pickup one?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-16-2021, 01:40 AM | #4 |
I think it is the same as the pickup. The one from my Suburban was not there when I purchased it. So I am looking for some photos of how it mounts and what it looks like. Thanks
04-16-2021, 08:12 AM | #5 |
They aren't great pics, but this is what was on my 63 when I bought it. I've since removed it to go with a chain style hoist from a 90s Nissan pickup. I had to change because the spare tire I chose was too wide for the original carrier.
The factory has a long bolt on each side. One bolt has a special nut that helps hold up the piece that goes under the tire. If you do a search over in the parts section of the board, you will be able to see some better pictures of it.
04-16-2021, 02:17 PM | #6 |
Here is what I had under my 1961 Suburban, albeit a bit warped. I'm don't recall how it mounted up and I only have the one bolt/nut combo
MusicMan70 1961 GMC Suburban |
04-16-2021, 03:10 PM | #7 |
Super thanks for taking the time and posting the photos. How wide and deep it the bar? From the photos I can fab up a new bar that looks reasonably close to factory.
04-16-2021, 04:20 PM | #8 |
It is 1 1/4" deep in the middle and 2 1/2" wide and curved a bit and the plate is 6 1/4"x 6 1/2"
04-16-2021, 04:21 PM | #9 |
Thanks for the info.
04-16-2021, 04:25 PM | #10 |
you are welcome!
