Old 04-08-2021, 03:08 PM   #1
mrhurt73
is this crossmember 6 cyl manual only?
I am in need of finding a transmission crossmember, but i see conflicting info on which ones i could replace it with.
the truck is a 1971 C-10 with straight 6 and 3 speed manual transmission
found a truck with V8 manual transmission and crossmember is in different holes
see the attached pictures i took for reference, any help will greatly be appreciated
and yes it broke the bellhousing, i think its only a 6 cyl bellhousing part also because of starter mounting in bellhousing
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 04-08-2021, 03:20 PM   #2
MJN
MJN's Avatar
Re: is this crossmember 6 cyl manual only?
Can't help with the crossmember but the starter was mounted to the bellhousing for manual transmission trucks regardless of engine up to 1973. So that bellhousing mounted starter is not just a six cylinder part.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-08-2021, 03:22 PM   #3
mrhurt73
well thats a start, thanks for the info.
hopefully someone knows about crossmember
My Projects-
Old 04-08-2021, 05:01 PM   #4
gmc684x4
That bellhousing also has two different hole sizes one for sm420 sm465 has a larger hole
I can not say if crossmember differs
In c10 trucks they moved the v8 further ahead inches frame to a 6 cyl which was in in back set of engine mount holes
gmc684x4 is offline   Reply With Quote
Old 04-08-2021, 05:24 PM   #5
Furno68C20
Left SM420 Right SM465
That crossmember looks like a 6cyl. I could be wrong. GrumpyOldMan would know
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Furno68C20 is offline   Reply With Quote
Old 04-08-2021, 05:38 PM   #6
mrhurt73
the one on the right looks like the one i got. this one is a 3 speed transmission i wonder if i found a SM465 bellhousing would it still work? the bolts should line it up as far a centerline. don't know, just thinking out loud
My Projects-
Old 04-08-2021, 06:17 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Read through this thread.
http://www.67-72chevytrucks.com/vboa....php?p=8633251
LockDoc
Leon
Old 04-08-2021, 07:50 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
L6 -only diagonal crossmembercrossmember, but i see conflicting info on which ones i could replace it with.
Could be a special L6 292-only crossmember. They were only used on 4x4 trucks with a 292. 250s could be mounted on a conventional crossmember. C/ model trucks didn't need a special crossmember for a 292.
See pix:
Old 04-08-2021, 10:04 PM   #9
Grumpy old man
Grumpy old man's Avatar
You have a 6 cylinder manual cross member , You can see in these pictures the V8 cross member mounts further forward in the frame . How did you bend it like that ? you may want to take some X measurements to check if the bent cross member tweaked the frame out of square ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 04-09-2021, 11:59 PM   #10
69GMC2004
Active Member
That looks like the same crossmember that was in my 292 SM465. Mine was a but straighter though. It mounted in the holes directly in front of the front cab mount.
69GMC2004 is offline   Reply With Quote
Old 05-04-2021, 12:02 PM   #11
mrhurt73
I found a crossmember and bellhousing while i was in pigeon forge for the spring rod run.
price was higher than it should have been, but its pigeon forge prices. and i was there and it was there. so now its sandblasted and painted, going in frame. and i did check frame, got lucky the old crossmember started to rip at the rivets instead of pulling frame.
thansk everyone for all the info
My Projects-
Old 05-04-2021, 12:42 PM   #12
Grumpy old man
Here are a couple more pictures of the V8 vs 6 trans cross members the V8 is on the left .
The bell housings are different by the size of the hole for the trans , the 67 bell housing is smaller .
Old 05-05-2021, 02:06 PM   #13
'68OrangeSunshine
Bellhousing for the MY '68-later SM 465 has casting numbers: [GM5] 3925505 = 5-1/8'' diameter.
SM420 bellhousing was [GM11] 3815891 = 4-9/16'' dia.
