04-10-2021, 03:12 PM | #1 |
trying to pull the harmonic balancer - questions
Let me preface this with I know I'm dump. I'm just learning.
Have a 72 chevy c10. Pulling the harmonic balancer. Have removed crank pulley etc. Connected puller to harmonic balancer. Have removed radiator. When I try to put my impact on the end of the puller, I can because of the lower radiator support. I am being dumb, or do you have to also remove the lower radiator support? Thanks and be gentle. |
04-10-2021, 03:36 PM | #2 |
Re: trying to pull the harmonic balancer - questions
Do you have room to use a wrench on the puller? That's what I did the last time, and I inserted a wooden dowel through a couple of the puller bolts to keep the crankshaft from spinning.
04-10-2021, 03:36 PM | #3 |
Have you tried a breaker bar
With a pry bar in the puller to keep engine from rotating? .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-10-2021, 03:47 PM | #4 |
Never mind.
No bolt. Pulled it fine. Just being a chicken. LOL |
04-10-2021, 03:48 PM | #5 |
Cool
Glad you got it .
04-10-2021, 07:33 PM | #6 |
04-10-2021, 08:22 PM | #7 |
Remember to use a pusher to put it back on. LOL. Also check the ware on the balancer seal area. If the is worn they sell a sleeve and seal combo to fix it. You don't have to replace the balancer.
