Old 12-21-2003, 10:13 PM   #1
griesel72
griesel72's Avatar
van tilt help
What do i have to do to convert a van tilt to work in my truck. Somebody told me that i need to cut off part of the shaft, and swap wiring. can i use the harness out of my old straight column or do i need to use something else
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 12-21-2003, 10:22 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Don't cut the shaft, collapse it with a hammer.
The wiring might just plug in, if not, GM sells an adapter for like 3 bucks that makes it a plug in deal. I've got one in the garage if you need pictures of it. It depends on which shape of connector your van column has.
Old 12-21-2003, 10:33 PM   #3
griesel72
griesel72's Avatar
Tx, Where do i collapse it? Also, this tilt, the wiring is cut, so i have no plug. what do you think i should do?
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-21-2003, 10:51 PM   #4
imdarren
imdarren's Avatar
Is what Tx Firefighter means is,
the shaft that goes between the steering box and column shaft needs to be shortened.
You can do this by removing it (The shaft) and hitting it on the end with a large hammer.
These shafts were designed to collaps in the event of an accident anyway. There is a small plastic peice in there keeping it from sliding easily.
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 12-21-2003, 11:00 PM   #5
Tx Firefighter
Darren is correct.
Old 12-21-2003, 11:04 PM   #6
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
I found a tilt steering in a 81 chevy van and put it in my 72 c-10. I didn't cut or knock anything off. As far as your wiring I was able to splice mine together using the old u-shaped connector off of my old column. The van tilt column had a flat connector and the one you have to buy just plugs the flat end into a ushaped connector. The wires are the same color so you can just cut the u-shaped connector out of your old steering column and and wire it into the end of the wires on your van tilt. Then they'll be able to plug together!!!
WRMZ71 is offline   Reply With Quote
Old 12-22-2003, 12:35 AM   #7
griesel72
griesel72's Avatar
Thanks guys for all the help. Just to double check, i need to install my column, and then hit it with a hammer at the south end (how much do i need to shrink it) And then cut off the u connector on my old column and splice in into the van's wires that are already there?
Thanks again
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-22-2003, 12:39 AM   #8
Tx Firefighter
The neutral saftey switch needs to be moved up too. Do a search for that. I'm about to do one myself next week.
Old 12-22-2003, 04:31 AM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Hey Tx Firefighter, if it's a van column the Neutral Safety needs to be moved Down as they are already too high! Also do not install the column and try to collapse the shaft collapse it FIRST, then install the column.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 12-22-2003, 09:20 AM   #10
JimKshortstep4x4
Talking
The Van tilt is 2 1/2" longer than the truck tilt.
Here is a link. Click on Magazine tech articles, tilt will be first article.
Jim
http://www.geocities.com/sshevnock/home.html
Old 12-22-2003, 12:46 PM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Great article - thanks for the link Jim.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-22-2003, 12:53 PM   #12
griesel72
griesel72's Avatar
THanks guys, i am well on my way to getting back on the road. One other question, on my van tilt, i have a couple of wires that i don't have on my old column, one (set) of three really small diameter wires that are clumped together and one single grey wire. What do i do with those?
Thanks again for the help
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-22-2003, 01:32 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The gry wire is the power to the shift indicator light. Put a femail spade connector on there nad plug it into the terminal on your fusebox labeled lights.
Old 12-22-2003, 02:04 PM   #14
JimKshortstep4x4
Talking
The three small wires are for cruise control.
Jim
Old 12-22-2003, 02:45 PM   #15
Yukon Jack
Post Whore
Yukon Jack's Avatar
While we are on the subject of van tilts - if I'm going to be using a van auto tilt a 4 speed truck - am I correct that I don't need to worry about the neutral switch?
Old 12-22-2003, 02:52 PM   #16
griesel72
griesel72's Avatar
my 71 that orginally had a 4 speed has a green harness that ran directly from the trans to under the dash, so i think you're right, just ditch the switch.
Thanks to all who helped me through this i'll post some pics when i get it done.
david
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-22-2003, 02:54 PM   #17
Linus0014
Guest
Posts: n/a
http://67-72chevytrucks.com/vboard/s...=dremel+column
Here is the thread for the N/S switch to relocate it.
Old 12-22-2003, 03:09 PM   #18
racedvl
racedvl's Avatar
Jack you are correct.
racedvl is offline   Reply With Quote
Old 12-23-2003, 01:45 PM   #19
griesel72
griesel72's Avatar
one more question, this is my van tilt next to my old column, is there supposed to be that much difference in length, or am i missing something?
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-23-2003, 01:51 PM   #20
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Yes. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-23-2003, 02:06 PM   #21
griesel72
griesel72's Avatar
I slid my column through my firewall and the gear shift lever against the lower dash, and it's not even close to as long as it needs to be, maybe 12-18 inches too short, am i missing a part, or did i do something wrong?
DAvid
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-23-2003, 02:24 PM   #22
griesel72
griesel72's Avatar
pictures of problems
Inside is as far "in" as it can go
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-23-2003, 02:25 PM   #23
griesel72
griesel72's Avatar
And it seems the shaft is too short
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-23-2003, 02:27 PM   #24
JimKshortstep4x4
Talking
Griesel72,
You will need to remove the steering shaft extension from your old one, shorten it 2 1/2" and install it onto the Van tilt shaft after you remove the flange.
Recheck the photo that has the extension shaft circled.
Jim
Old 12-23-2003, 02:38 PM   #25
griesel72
griesel72's Avatar
Jim,
I think this is about the 10th time you have saved me @ss. thanks for the help
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
