Need help with vortec 350 manual trans swap
Morning fellas,
Finishing up my L31 vortec 350 build for my 64 step side and trying to figure the flywheel, clutch and starter situation. Here's what in the truck now: -1977 305 (lol...i know...hence the engine swap) -factory 1964 bell housing and mechanical clutch linkage -1992 world class S10 speed conversion I know I have to drill and tap the vortec block for the z-bar ball stud ( i had to do it on the 305 that's in it now) I know I need the vortec flywheel due to the 1 piece rear main seal. My questions are: 1. Because there's very low mileage on the clutch that's in the truck now, can I use that clutch on the vortec flywheel? The reason I ask is that the clutch for the vortec flywheel is 12 in and the clutch in the truck now is 11in. I'm pretty sure the mounting is the same for a 10.5 and 11 is the same, is it the same for a 11 and 12 in clutch? Will they interchange or do I need the vortec clutch? Here a link to the vortec flywheel: https://www.rockauto.com/en/moreinfo...1086&jsn=11086 Link to the vortec clutch: https://www.rockauto.com/en/moreinfo...jsn=__GIP__4__ Link to the flywheel I have in it now: https://www.rockauto.com/en/moreinfo...=8&jsn=8&jsn=8 Link to the clutch kit in it now: https://www.rockauto.com/en/moreinfo...jsn=__GIP__4__ 2. Because both the flywheel in the truck now and vortec flywheel are 168 tooth and have a 14 in outer diameter, I can I use the same starter, correct? 3. Because the pilot bearing in the truck now and the vortec one have a .59 inner diameter, there shouldn't be any issues? |
![]() Join Date: Jan 2011
Re: Need help with vortec 350 manual trans swap
Till you put your hands on the fly wheel and see what its actually drilled for I would say maybe on the clutch. Rest of you plan looks fine. The starter will work if the flywheels are both 168.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
