Old 04-26-2021, 09:29 AM   #1
MT65
Question Wiper motor wiring
Finishing the under dash stuff, found my original wiper switch has only one terminal, the motor has 2....switch has 2 positions as per a two speed...checked continuity one original harness, yes one wire from switch to motor, will check other wire on motor for termination...not understanding how GM made this work...surely the switch isn’t a grounding point. Any thoughts???
MT65 is offline   Reply With Quote
Old 04-26-2021, 10:12 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Wiper motor wiring
You should have a yellow wire from the fuse panel to the motor. A light blue wire from the motor to the switch. The motor grounds thru the switch, so make sure grounds...
Old 04-26-2021, 11:28 AM   #3
clemsonteg
I've been using this http://67-72chevytrucks.com/vboard/s...19&postcount=4 and the American Autowire diagram https://www.americanautowire.com/med...20IN%200.0.pdf
clemsonteg is offline   Reply With Quote
Old 04-26-2021, 04:27 PM   #4
MT65
Yes, checked that this morning, never had a wiper switch be the ground in the past, knowing that it was marginal when I drove home in a snow storm through most of eastern Oregon, I just ordered one of Newport Enginnering new ones. Do not want any issues in the future, and one more speed can’t hurt.
I had luckily kept the old harness and panel to check items like this, thanks for the help tho......
Old 04-26-2021, 04:30 PM   #5
MT65
Originally Posted by clemsonteg View Post
My switch only has one terminal, I think it has been fooled with in the past, new parts due in Thursday....
Old 04-26-2021, 05:10 PM   #6
nsb29
nsb29's Avatar
The reason that it uses a ground is when you turn the switch off there still has to be power to the motor so it can park With the 2 speed switch and motor you basically have two grounds one ground to Low speed the other one for high-speed
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 04-27-2021, 07:08 AM   #7
The Rocknrod
Moderator
On an OEM motor the wiper switch IS the ground. The yellow is power, the motor grounds THRU the switch. - https://67-72chevytrucks.com/vboard/...d.php?t=695112
When the wiper switch is turned on, it completes the circuit to ground (the dash). - http://67-72chevytrucks.com/vboard/s...d.php?t=413551
