Old 04-30-2021, 07:35 PM   #1
Jmoney01
Engine swap question
Pulled the 292 out of my 80 gmc. Installing a 350. The driver's side motor mount (the piece the clam bolts to) has 2 sets of holes. The 292 was in the lower. Which ones should I go with?
Jmoney01 is offline   Reply With Quote
Old 04-30-2021, 08:20 PM   #2
kwmech
Re: Engine swap question
Front sets, you want the mounts across from each other with the V8. I think that may however pull the trans forward though. I'm not to keen on the 292 placement
Old 04-30-2021, 08:34 PM   #3
1976gmc20
Anything wrong with the 292 ?
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 05-01-2021, 07:19 AM   #4
Jmoney01
Ok, I'll move it where they are straight across, but there is a set of holes up and down on the driver's side. Looks like it will rock the motor if it's not Right. The 292 is worn out. This is a one ton dump truck and has always had a load behind her. It's been a rough 40 years on her
Old 05-01-2021, 10:45 AM   #5
1976gmc20
Okay, I was sort of looking for a usable 292 to replace an oil burning 350 (reverse of what you are doing).
I did do an in-frame ring and bearing job on a 292 for someone about 40 years ago.
Old 05-02-2021, 07:15 PM   #6
Jmoney01
When I moved the passenger side pedistal back to line it up with the driver's side, it halfway off the k member. If I move the driver side forward, the bolts don't fit. Doesn't seem right to have to drill them out. Any ideas?
Old 05-02-2021, 07:46 PM   #7
I think it is actually a different passenger side mount (stand) for the V8 vice 292. Not positive, but I remember folks talking about changing mounts (stands)when they went from 6 to 8
Old 05-03-2021, 10:53 AM   #8
Jmoney01
Looks like I'm heading to the junkyard tomorrow....
