05-03-2021, 09:25 PM | #1 |
Jumps in Reverse
I just took my 70 swb out of hibernation. Power steering fluid and oil were down and battery is on its last legs. What concerns me though is when I put it in reverse it jumps a few inches backwards even with the brake on. Does not do that when moving forward. Hoping my rear diff isn't shot, looking for a diagnosis and advice. Thx in advance!
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
05-03-2021, 09:29 PM | #2 |
Re: Jumps in Reverse
A stuck or dragging brake? Automatic or manual transmission? If auto did you check the fluid?
05-03-2021, 10:24 PM | #3 |
It'd an automatic, don't think it is a brake issue. Will check the fluid level, thank you.
05-03-2021, 11:36 PM | #4 |
The Older Generation
Does it kill the engine if you put the brake on in reverse? My '39 Ford Coupe did that and it was a vacuum leak in the line to the modulator. 350/TH350. Check all of your vacuum hoses.... LockDoc
05-04-2021, 08:04 AM | #5 |
If it hits hard in reverse, maybe the idle is too high??
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
05-04-2021, 12:04 PM | #6 |
No, it doesn't want to stall, it just flies backward
05-04-2021, 12:04 PM | #7 |
I was thinking that, but wouldn't it do the same moving forward?
05-04-2021, 12:32 PM | #8 |
Maybe a bad motor mount ?? .....
05-04-2021, 12:40 PM | #9 |
My guess is brakes . Reverse is a very low gear as opposed to forward gears . So it can overpower the brakes if they aren't working properly.
05-04-2021, 01:00 PM | #10 |
I would still check all the vacuum lines and the modulator. LockDoc
05-04-2021, 03:42 PM | #11 |
Sometimes the slack in the differential spider gears can cause slack in the differential.
Looks like excessive backlash in the gears but it's not. It can jump when the slack it taken up. A lot of good suggestions on things to check on. This Board is a wonderful resource. Rick |
05-04-2021, 03:56 PM | #12 |
I'm thinking brakes. Imagine if the hardware in the rear needs adjustment or is just worn out. Add a little slack in the gears the rear may not have much rear brake force applied when you place it in R. With the R being lower geared and nothing stopping the rear axles it could pull the truck back a bit. Try putting your parking/hand/foot brake on as hard as you can before shifting to R. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-04-2021, 05:31 PM | #13 |
Thanks for all the suggestions, I will be checking my vacuum hoses and modulator, but the brake question is a good one too, it has 4 old drums on it and it might be as simple as that. Thanks again everyone I appreciate it.
