![]() Join Date: Nov 2013
Trailing Arm Bushings
Yes...I searched until I was cross eyed
I noticed the trailing arms on my '69 frame had floated over against the mounting bracket. I will be installing new bushings but my question is: Should the arms float in the mount? You can see some rust where the arm rubbed the bracket...I pried it back over to the center
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Re: Trailing Arm Bushings
Put a couple of washers on the bolt @ the front of the arm (inside of the ears) when you update things. The washers will take up any slack & help keep things centered.
![]() Join Date: Mar 2015
No they shouldn't float.
The rubber has separated from the inner race. The bolts retain the center piece and the movement is internal to the rubber insert. At least when everything is working correctly. After replacement you leave the center bolt loose till their is weight on the wheels. Then it is torqued. That centers the rubber so it doesn't tear. Rick |
Post Whore
![]() Join Date: Feb 2016
The bushings should prevent the arms from rubbing during normal articulation. I would wager that the rubber in your bushings are no longer attached to the center sleeve allowing the arm to push to the side and rub. I am guessing it was a bit noisy.
If your interested here are a couple posts from when I replaced my bushings. https://67-72chevytrucks.com/vboard/...698377&page=11
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks for the replies...much appreciated
I will be removing the trailing arms soon and doing shock relocation I also got new U-bolts for the rear mounts I'll let you know what I find out when they come off
