05-19-2021, 05:13 PM | #1 |
Drip rail deflectors
How do they work? I’ve not had any on the Fawkes for 22 years now, but the passenger side is starting to leak. I can’t, for the life of me, trace the source!
'72 K5, known as 'the Fox.' |
05-19-2021, 05:14 PM | #2 |
Re: Drip rail deflectors
Pic
05-19-2021, 07:54 PM | #3 |
The drip deflector bridges the gap between the windshield frame and the top. It works pretty well. Make sure you put a bead of silicone on it before you install it.
Mine are pretty old and cracked, but my new Softopper should be here soon...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-20-2021, 10:51 AM | #4 |
I've filled that gap with silicone in the past, without luck... Are those things magic?
05-20-2021, 12:38 PM | #5 |
They're not magic, but if you run a bead of RTV where they contact the top/pillar they work pretty well. I'll still get an occasional drip, but not nearly as much as I did without them.
