05-31-2021, 03:52 PM | #1 |
Sway bar on a 63 with a later model cross member
Installed the 74 C20 cross member, and the sway bar doesn’t bolt up right. It seems I would have to create a new mounting position. However, the stock sway bar from the 74 cross member is to short. It lines up with the mounting positions on the control arms, it’s the frame mounting positions that do not line up. It’s too short.
Is there an aftermarket sway bar that will fit?
1963 C20, small window, long bed 292, 4-speed |
05-31-2021, 11:26 PM | #2 |
Re: Sway bar on a 63 with a later model cross member
Do you have factory frame stands for the sway bar on your 63? I didn't on mine, and when I added my sway bar from a late 70s 3/4 ton, I had to bolt the bar on with the suspension on the ground to get it done
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-31-2021, 11:37 PM | #3 | |
I did have a sway bar on my63, it was smaller diameter, and I gave it away when I sold my old front cross member. The one that came with the 74 cross member doesn’t fit because it isn’t long enough, front to back. It bolts up to the lower control arms, it just doesn’t come forward enough to mount to the frame where the old brackets were.
05-31-2021, 11:42 PM | #4 |
Oh, I understand what you mean now. Sorry I'm no help as I haven't had that issue before
06-01-2021, 08:45 AM | #5 |
Don’t know how much to short you are but if it’s a small amount maybe you could move your frame stands. I took this route I think I got it through Summit, Much better design than the original set up no binding but you do have to drill new holes
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
06-01-2021, 02:28 PM | #6 | |
Also, can you post a closeup of the mounting to the control arm? I can’t tell from the pic. Did you have to modify the control arm, drill holes in it?
06-01-2021, 05:47 PM | #7 | |
Put the center of whatever sway bar you have on a jack. Mount each side to the a-arm. Raise the bar until the frame rail mounts contact the frame. Drill holes where necessary. Install hardware & tighten.
06-01-2021, 07:56 PM | #8 |
Scoti pretty much summed it up you have to drill one hole in each A-frame and two in each frame rail no stands required the truck is a 65
06-01-2021, 09:17 PM | #9 | ||
Just not going to work.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 06-01-2021 at 10:14 PM. |
06-02-2021, 09:05 AM | #10 |
63/72 is the same 74/80 sum thing is the same all though I see where some of the aftermarket ones advertise 63/80 sum thing but they are a lot more money I would get an aftermarket one for 63/72 if you want I can get you measurements off mine
06-02-2021, 09:34 AM | #11 | |
Was the bar you pulled off & sold w/the previous suspension factory installed & similar to the unit you're installing w/the later model year x-member? I never knew 63's came w/sway bars but I suppose they could have.
06-02-2021, 09:57 AM | #12 | |
Mine is about 15” deep, 38” wide.
06-02-2021, 10:00 AM | #13 | |
The 73 original cross member did have a sway bar. There are holes in the frame. That original sway bar was a smaller diameter. The one from the 74 cross member is 1”.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 06-02-2021 at 10:17 AM. |
06-02-2021, 11:25 AM | #14 | ||||
Were the end link bushings the same style as the frame mounting bushings? Were there frame stands that the bar mounted to or was the previous set-up (that you sold) bolted directly to the frame? These 63-87 C10 trucks had the factory sway bars mounted to factory attached frame stands & used the same bushing arrangement @ the frame & control arm pivot points. We need to understand what you likely had vs. what you're trying to put in. Knowing that info might shed insight on the differences you're experiencing.
06-02-2021, 12:24 PM | #15 | |
Guess I will have to look for an aftermarket sway bar.
06-02-2021, 12:52 PM | #16 |
This is as close as I can measure I cold be off a inch
06-02-2021, 04:40 PM | #17 | |
Just a thought.... P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
06-02-2021, 05:56 PM | #18 |
I don’t think I need to make new brackets, the brackets I have should work fine.
Maybe I can get a steel rod and extend each leg a few inches. Cheaper to buy steel rod and weld it on, rather than buy a whole new sway bar.
06-02-2021, 06:00 PM | #19 | |
The options are drill new holes in the frame to use the 74 model bar or spend the money to purchase an aftermarket set-up.
06-02-2021, 06:26 PM | #20 |
Can’t use the existing 74 bar unless I weld on a 5” extension. I think the bar would be too close to the pitman arm and idler arm.
06-02-2021, 06:35 PM | #21 | |
Check clearances so you're not 'guessing'. If anything makes contact before the frame stands contact the rail/s, you have your answer. Buying an aftermarket set-up may be the easy button or it could lead to additional frustration if the bars 'arms' are not long enough. I know from experience searching various sway bar criteria, not all manufacturers offer the dimensions to help make an informed decision. They usually will just offer that "it's intended to work on 6X-8X year model" truck.
06-02-2021, 06:50 PM | #22 |
Could the sway bar be upside down?
06-02-2021, 07:00 PM | #23 |
Turning it over doesn’t make it any longer. I thought about that too; it just changed the angle where it mounts to the control arms.
06-02-2021, 07:02 PM | #24 | |
06-02-2021, 07:17 PM | #25 | |
You also did not have the frame stands in place. They would space the bar out slightly away from the frame possibly preventing clearance issues.
