newly minted old timer
picked a bad time for an ls swap--- dakota digital dash
I've decided to get one of the Dakota digital rtx-67c-pu-x dashes to make things easy. the problem is the world seems to be out of them. this isn't the only part or item that is out of stock.
you all noticing that everything is getting hard to find... the world ending? lol
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
Re: picked a bad time for an ls swap--- dakota digital dash
I think mine took 4+ month a few months ago.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Unless Dokata has it on the shelf, which will likely be in a nasty face and/or led color, the wait to build is 12 weeks or so I believe.
The delay is most likely due to the worldwide micro chip shortage. Just run your original cluster until you can get the digital.
Edit: Sorry, you said "easy". To me, easy is using the original. Might have to wait on speedo working (depending on transmission) until you can get the Dakota Digital. Oh, and drill the head for the proper temp sender, and mod the oil sender to work with the mechanical gauge. Ok, I get what you are saying. But, I did all that because I like the original look. I was going to use the Dakota Digital ECD-200BT-1 to drive the speedo, but I bet that is in short supply as well. |
Earlier this year same story with LS swap harnesses. Speartech was 13-14 weeks at best.
China virus had companies and manufacturing close their doors and lay off workers for months. Catching up with the same or less workers isn't easy. Finding people willing to work also seems to be an issue just about everywhere since the lockdowns.
![]() Join Date: Dec 2014
Even if they are USA made, there are lots of little doo dads that they get from overseas. For whatever reason there are a lot of shortages of little things due to world events.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
This is it. There's longer lead times on a lot of things. It took me 3 months to get some generic 2-digit 7 segment LED displays.
I have found that almost every large size replacement radiator for 70's GM vehicles are not in stock on Rockauto.com
It was odd that a couple radiators for a couple applications were not available. But if you look at almost any GM car from the 70's almost every large HD radiator is not available. I don't know what's going on with this world but it's annoying me. |
Doesn't sound like a little do-dads problem with raditors. If you need one, I heard last week that ECP has them in stock.
A lot of supply problems where I work. It isn't just car parts, a lot of industrial parts are hard to get right now.
![]() Join Date: Jun 2019
So now that its been a while how does this converter work in everybody's Trucks?
(i.e. Would you buy it again type of discussion)?
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
#13 |
I have run Dakota's in several hot rods including clients. Love them, quality product.
#14 |
I have an RTX coming from Dakota Digital that has been shipped. Should be here any day now. Contact me if you are interested. 765 661 1723
#15 |
![]() Join Date: Dec 1999
I have the RTX gauges and they are great. I would definitely do it again. I have LS swap and the OBD BIM made the hookup very easy.
#16 |
No problem getting them anymore. Times change fast these days.
