07-12-2021, 04:05 PM | #1 |
Charging voltage seems too high, is voltage regulator adjustable?
I've had my 65 C10 283 for a couple of years now. It has an aftermarket ammeter that always reads close to the center so I have never worried about the charging system. I recently started using one of those digital volt meter/USB ports plugged into my cigarette lighter socket to charge my phone. This particular tech will cause the voltage reading to flash if it goes below 11 or above 15. I notice that when I am driving my voltage runs between 15.3-15.7 and this seems a little high? Key on engine off voltage is like 12.8 and engine idling is around 13.8 but when the RPM's come up and the alternator is spinning faster, the volts goes above 15. I remember some of the older voltage regulators were adjustable but wanted to ask before buying a new one. I want to stay with the OE external regulator setup for now. Thanks
1965 Chevy C10 283 SM420 Long Fleet "The Old Man" 1970 Chevy C10 350 SM465 Long Fleet "Dave" 1975 Toyota FJ40 "Mr Grinch" 1969 Pontiac Firebird 2001 Chevy Tahoe 2001 Toyota 4Runner |
07-12-2021, 07:44 PM | #2 |
But Found Her 25yrs Later!
Re: Charging voltage seems too high, is voltage regulator adjustable?
I'm not sure if it's adjustable in itself.
But you are correct that 15 is too high: https://askinglot.com/what-causes-an...t-high-voltage
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-12-2021, 07:59 PM | #3 |
Who Changed This?
Yes. See page 6Y-11 in this manual-
http://www.mediafire.com/file/e7v2am...Truck.pdf/file Download that thing!
07-13-2021, 11:44 AM | #4 |
The original Delco reg. is adjustable with a screw at the base of the spring on the voltage side of the reg. After market regs. adjust by bending the tab that holds the spring.
The voltage will drop about .2 volts when you put the cover on. George |
