Old 07-20-2021, 01:57 PM   #1
609thomasm
609thomasm's Avatar
5.3 & 4L60E swap in 72 K10 question
So I am planning to start this project soon. I am going to use the advance Adapters kit 50-5310 to mate the 4L60E to the NP205 transfer case.(figure 8 bolt pattern) My question is about the clearance between the CV yoke (spicer) and the transmission. AA states in their instructions that there might be clearance issues. They did not have any specifics and referred me to High Angle Drive Line. They said with my front shaft angle at 15 degrees I am right at the limit. Truck is lifted 4 inches. Anyone out there with this clearance issue? Trying not to spend $750 on adapter kit and installing the shaft in the 4L60E only not to be able to install the front shaft. Thanks for any input.
609thomasm is offline   Reply With Quote
Old 07-20-2021, 04:51 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 5.3 & 4L60E swap in 72 K10 question
The driveshaft should clear with the lift.
You need a rear speed sensor to make the transmission shift. Are you going to mate a VSS to your 205?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-20-2021, 04:52 PM   #3
Thealien
Thealien's Avatar
I had pictures of the interference and what I did to alleviate it in one of the links in my signature. But I have been unable to find them, sorry.
I didn't have a lift, your 2" should help.
I ended up cutting the corner of the pan and having it welded back on backwards. It worked and I never had a problem. To me the transmission pan interference is the biggest negative about an LS/4L60 4 X $ swap. I have looked into the transfer case that comes with an LS pull out and changing the front axle to a drivers side drop (which is what the 4L60 was designed to be used with). That option has its own issues.
You should be OK dimpling the pan?
Old 07-20-2021, 04:53 PM   #4
Thealien
Thealien's Avatar
The advance adapters 4 bolt to 6 bolt NP205 adapter has the VSS provision.
Old 07-20-2021, 06:38 PM   #5
609thomasm
609thomasm's Avatar
Thanks for the input, I plan to use the provision in the adapter for my VSS. As far as the lift helping, I was told that the lift would make clearance worse. I don't see how that can be since the shaft is going down away from the pan right from the T-case. I can notch the pan if it's a little to close. I have a lot of things to figure out. I do have a complete 04 Tahoe as the donor so I have all the goods from it.
Old 07-22-2021, 12:28 PM   #6
1972CST
1972CST's Avatar
I have installed a 5.3/ 4L60E and kept the NP205 in my 72 Blazer. I am running a 2" lift and it looks like driveshaft clearance will be tight but I have not installed it yet. I used the AA kit and Dirty Dingo engine mount. So far I am pleased with the swap, still have a few more details to sort out.
1972CST is offline   Reply With Quote
Old 07-22-2021, 12:55 PM   #7
JJH Jimmy
JJH Jimmy's Avatar
I have the AA 4l60e to NP205 in my Jimmy with a 4" lift. I ended up notching the pan like Thealien said. If i remember correctly it would have cleared with a 1/16th of an inch but that is way too close in my opinion. The last thing i wanted was tranny fluid on a hot exhaust pipe. That's a fire that you wont put out.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 07-30-2021, 09:35 AM   #8
Acregger
I have a 2 inch lift with 4l60e/np205, front drive shaft was very close I just dented the corner of the pan with a block of wood and hammer and now have clearance
Acregger is offline   Reply With Quote
Old 08-28-2021, 09:33 PM   #9
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I put a 5.3 LM7 4l60e in my 70 K10. The clearance is tight for sure. I did a little grinding work on the yoke. I did not have to dimple, hit or dent the transmission pan. I also used the VSS signal in the AA NP205 to 4l60e adapter. I made a special plug for the vacated spot in the NP205. You can check out my build thread in my signature.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 10-01-2022, 05:52 AM   #10
jmader
jmader's Avatar
Hey guys I'm doing the same swap here but the kit didn't come with instructions and this is the only thing I can find on their website.
file:///C:/Users/Mader/Downloads/50-5310-1.pdf
Does anyone have a link to better instructions? I'm not having any luck finding anything.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
