Old 07-23-2021, 08:21 AM   #1
62 Barnfind
62 Barnfind's Avatar
V8 badge location
Can someone tell me the measurements for the location of the 57 V 8 badge on the door?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 07-23-2021, 09:40 AM   #2
57FleetsideC4
Re: V8 badge location
Hi, I got this image from a guy who had just bought a original V8 truck and it looked like it. I asked for measurements and this is what I sent. They look ok. This is what I will use on my 57 when it comes time. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 07-23-2021, 12:50 PM   #3
_Ogre
_Ogre's Avatar
hmmm.... had two 58s with V vin and never had the V on the fender
58TRUK is a V8 truck, chevy may have phased it out for 58?
shop air compressor timer
Old 07-23-2021, 04:29 PM   #4
1project2many
I have an original V8 57. I will try to remember to measure V location to confirm dimensions.
Edit: I measured from front of door to bottom center of V and from beltline to bottom center of V. I came up with 7 15/16" from front of door and 1" from body line.
Ogre... No fender V in '58. Hood ornament should have a V.
For anyone else looking, 55 + 56 V's are on the fender. GM's Factory Assembly Manual has dimensions.
https://www.trifive.com/d1/55-59Assy.pdf
If you go to page 715 (it shows up as 4XX-25 in the PDF viewer I'm using) you'll see dimensions for the 55-56 side spear and V location for 1/2 ton trucks.
Page 727 (4XX-37) shows V location in larger trucks.
1project2many is offline   Reply With Quote
Old 07-25-2021, 10:00 AM   #5
62 Barnfind
Thanks everybody! I will be able to get it right or close to right with the info you gave me.
John Z
62 Barnfind
