Old 08-20-2021, 07:24 PM   #1
suburban99
suburban99's Avatar
15 x 10 wheels on a k10 what works good?
On my 72 K10 I run KO 35's and I need to get a wider wheel. Currently have 15x8 ralley's...looking for 15x10 to get more rubber on the road. Pictures are helpful. Thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 08-21-2021, 02:56 AM   #2
Richard
Re: 15 x 10 wheels on a k10 what works good?
4.5" is pretty standard on the production wheels. They look and work fine in many cases. My new 17x10 wheels are 4.5". If you want different than that you will probably have to go custom. Actually wanted a 17x9, could not find without going custom. Truck looks good, why not just run a lower pressure if concerned about wear? With the 35's I would not be worried as low as 25-28 psi.
Richard
Old 08-21-2021, 07:27 AM   #3
The 10" wheels might make the difference between rubbing and not rubbing. Is that a 4" lift? From my experience, 4" lift with 35/12.50s draws the line between fitting with 8" wheels and light rubbing with 10s. I currently have 8" wheels, 4" lift, and 285/75s. All work very well together. I want to go to 35s and really like 10" wheels better for the look I want. But when I had 35/12.50-16.5s on 9.75" slots they rubbed some when flexing on a turn. People seem to have no issues running 12.50s on 8" wheels. It seems to be the standard these days, when back in the day we always ran them on 10s. Less are should flatten your tread out
Old 08-22-2021, 12:34 AM   #4
suburban99
suburban99's Avatar
As far as air pressure goes, I have been running 27psi. recently changed to 24psi and the tread is flatter. I have read that 20 psi is minimum>>?
2015 Ram 4x4 1500
1997 Boxster.
Old 08-22-2021, 09:03 AM   #5
cadillac_al
That is the drawback of narrow rims and wide tires. You have to run them soft to get the tread to lay flat on the road. That could get interesting in high speed (speed limit) cornering. I tried it for a week or so and then bought 10" rims. That would completely change the look of your truck though. If you like the rally wheel look then I would be inclined to leave it as is.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-22-2021, 09:28 AM   #6
57taskforce
All about them K’s
57taskforce's Avatar
There’s this option too if you like the rally look.
https://www.cokertire.com/wheels/pic...15106l414.html
Awesome truck by the way! Love the marker lights on a short K10.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 09-13-2021, 10:29 PM   #7
Mike C
Mike C's Avatar
I would wait until you need new tires then I would go to a 16 or 17 or even 18 inch wheel. That lets you run 4.5” of backspacing instead of 3.5” which means it moves the outside of the wheel out 1” and the inside edge in 1” on a 10” rim which is common in 16 and 18 inch diameters. If you run 17’s the 9” is more common. That allows for more and better clearance to the fender cup and the frame IME.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-16-2021, 11:00 AM   #8
eager_adventurer
What style of 15x10 wheels are you looking for? Fuel wheels has a nice selection of 15x10 rims.
eager_adventurer is offline   Reply With Quote
Old 09-21-2021, 06:03 PM   #9
52napco
here are 15x10's with 33x12.50's on my 87 just for reference
52napco is offline   Reply With Quote
Old 09-26-2021, 10:27 PM   #10
Cabrust
US Mag Indy 15x10 w 33x12.50 BFG.
Cabrust is offline   Reply With Quote
Old 09-29-2021, 09:19 PM   #11
CG
BlahBlahBlah
Are those vintage mag wheels restored or are they new? If new can you tell us a little more about them. Where did you get them, approx cost, back spacing. Im a sucker for mag wheels, your truck looks great.
Old 09-29-2021, 11:03 PM   #12
Cabrust
I purchased new my friend, here is the link. Price, back space, etc.
https://www.summitracing.com/parts/usm-u10115008335
Old 09-30-2021, 02:48 PM   #13
57taskforce
All about them K’s
Hell yea thanks for sharing that, I had no idea you could still get them new. Love the slots. I see they have them in a 17x10 8 lug. Count me in! Thanks for sharing!
Tyler
