09-02-2021, 10:41 PM | #1 |
Center Pod in Instrument Cluster
I see most center pods are just blank with a pattern, printed on the glass I suspect. Some center pods have the turn signal indicators in them (and very large). Others contain a tach.
What determines if that pod gets the large turn signal indicators? Is it a certain trim level? Thanks!
1972 C20 402/TH400/3.54 Highlander 1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold) 1983 GMC Sierra Classic 2500 crew cab (sold) 1972 Chevy C10 Cheyenne Super (sold) 1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it) |
09-03-2021, 01:03 AM | #2 |
Re: Center Pod in Instrument Cluster
Turn signal indicators in the center might be for early year models? I would guess the tach would be an option rather than a trim level?
I'm sure better answers will follow... |
09-03-2021, 01:06 AM | #3 |
70+ ( Old Skool Club )
I have a 1967 C10 and it has the big turn signal flashers in the centre pod.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-03-2021, 01:49 AM | #4 |
If a truck has the "AMMETER OIL GAUGE" option on the SPID, then the gauge cluster will have the four additional smaller gauge openings along the bottom, and the large center gauge opening will no longer have the turn signals and oil and "generator" warning lights. I believe certain option packages included the gauge upgrade.
09-03-2021, 10:20 PM | #5 | |
This seems to be a bit of an unusual combination. A high percentage of the trucks I have looked at have those gauges. Thank again!
09-03-2021, 10:44 PM | #6 |
I am not an expert on what came as standard and optional equipment, but if you take a look at the 1972 sales brochure you will see the full gauge panel mentioned for the Cheyenne Super trim level, but not for the Cheyenne, Custom Deluxe or Custom. It is also listed as an option that could be added to any trim level, as well as a tachometer.
https://www.gmheritagecenter.com/doc...ruck-PCK-1.pdf I have owned four 67-72 trucks over the years, and only one of them (a 72 Cheyenne Super) came from the factory with full gauges. A previous owner of my truck installed a full gauge cluster, but didn't modify the wiring harness, so it didn't work right until I made the necessary modifications. Last edited by pjmoreland; 09-03-2021 at 10:49 PM. |
09-03-2021, 10:56 PM | #7 | |
EDIT: Added picture of the original purchase contract showing options and the addition of power brakes.
Jim Last edited by FirstOwner69; 09-03-2021 at 11:16 PM. |
09-03-2021, 11:38 PM | #8 |
All about them K’s
As said above Cheyenne super is the only trim level to have standard full gauges (tach/vac not included as standard) all others the gauge package was optional.
Jim, that’s pretty dang cool that after all these years you’ve still got all the original documentation. Not many can say they are the original owners anymore.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
09-04-2021, 12:33 AM | #9 |
They can't say "I'm really THAT old!" either. I also have virtually every receipt as well as a log of every gallon of gas used. Probably a bit OCD though!
Jim Last edited by FirstOwner69; 09-04-2021 at 12:46 AM. |
09-04-2021, 09:37 AM | #10 | |
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
09-04-2021, 10:13 AM | #11 | |
lol thought this through too much. |
09-04-2021, 03:23 PM | #12 |
Hi guys, mine has a vacuum gauge installed in the center pod. it looks to be a old pontiac gauge. but it looks stock. I like it. BROWN 70
