LWB fleetside wood dimensions
Hi guys, I'm looking to see if someone can confirm the size of the wood bed planks for a lwb 72 fleetside.
I gotten the following info from gmcpauls but want to know if anyone can verify that it is correct. I will be ordering my wood to size and would hate to get everything too small. 3/4" x 7 7/16 x 97 qty6 3/4" 5 7/16 x 97 qty2 3/4" 6 3/8 x 34.5 qty2 3/4" 6 3/8 x 25 qty2 TIA. |
![]() Join Date: Dec 2013
Re: LWB fleetside wood dimensions
They are all listed on the Mar-k website .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Not sure about exact for each plank, but do know it's about an 1" longer than 8 ft long. Because I went back with marine plywood in mine & ended up putting a piece of 1" square tubing at front to take up the gap from edge of plywood to header panel. But that being said I put bed together around the plywood & you'll need some clearance space to slip wood in already assembled bed panels, if that makes since.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
The Older Generation
I would go with GMC Pauls measurements. They are very knowledgeable about these trucks.... LockDoc
Active Member
![]() Join Date: Jun 2021
The numbers on GMC Pauls is good..I am just now finishing up my own cut wood and I used them for the sizes...I have a thread called good wood here in this forum .I will be posting some more pics of how the work is coming along on my 71 long bed
