09-09-2021, 02:18 PM | #1 |
I can’t be the only one
I can’t be the only one who starts a project and then let’s it go way overkill from what I started out to do. I recently decided to redo the front and rear suspension on my 71 GMC. After taking off the suspension and steering I figured I’d powder coat the control arms and rear trailing arms. Then it snowballed into pulley, brackets and air cleaner and such. Then inner fenders and radiator support. Rear main is leaking a bit so I’m already that far. If that’s coming out might as well send the engine mounts, crossmember and trans crossmember.
09-09-2021, 07:25 PM | #2 |
Re: I can’t be the only one
Don’t know what you are talking about
09-09-2021, 07:42 PM | #3 |
I screwed up and told the wife it will only be a couple weeks of me taking her parking spot.🤣🤣
09-09-2021, 08:19 PM | #4 |
Project creep lol! I figured a year......it took 5 Welcome to the club!
09-10-2021, 02:02 AM | #5 |
Nice to know there’s a term for it.
09-10-2021, 01:10 PM | #6 |
Post Whore
Wait!
Are you implying there's another way projects can go?????
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-10-2021, 03:02 PM | #7 |
On my 65 G10 van it went from simple suspension rebuild to completely modded. The engine, and tranny swap are on the simple side.
My Camaro has been in on/off project phase for a few years. Yet has had 3 different engines which have been graciously donated to other projects. Including my C10 engine swap. Will I learn yes. But I ignore the results because I am tired of high payments, and ugly cars. I need simple. A simple 450hp truck. As simple as that. One that I can fix while I promise never to do this to myself again, but I lie alot to myself. |
09-11-2021, 01:28 PM | #8 |
09-11-2021, 01:33 PM | #9 | |
09-20-2021, 11:16 AM | #10 |
That's about where I am. Seems there's no way out
72 C10 lwb fleetside -stock 350/350 combo |
09-20-2021, 02:24 PM | #11 |
09-20-2021, 11:03 PM | #12 |
low n' slo
when you find yourself saying.."well I might as well do this since I'm here" .....you're in trouble lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
09-21-2021, 10:30 AM | #13 |
I hear that. Walking that fine line, it looks like I'm under the influence
09-21-2021, 10:32 AM | #14 |
That's been my whole project....and all I wanted to do was change out the motor mounts.
09-21-2021, 03:15 PM | #15 |
What's project creep? I left the drivetrain and suspension alone but tore the cab and front end apart, welded in the new steel, and painted it in 30 days. That included reassembly and me redoing the wiring harness. Luckily it was a daily driver so I could say good enough. I did cheat and already had the doors done before tear down. That was an 18 hour a day marathon but it was all the time I had so it had to be done on time since I took vacation and did the work 7 hours from where I was living and the truck was my daily driver.
Seriously though the best way to avoid project creep is to keep it mobile, even if it's not a daily driver. Most things can be done over a weekend other than final body work and paint. This method let's you find the issues ahead of time and allows you to adjust for it. The second you stop using this method the project will scream to a halt. Also when this happens the checkbook tends to come out alot more. Face the fact that there are some really nice rides here but I don't know of to many Concourse restorations going on. Just my thoughts and advice. |
09-23-2021, 08:54 PM | #16 |
I’m just waiting on for my powder coating to be done next week. Hopefully my hardware will be done at the players next week or week after. Rear end is out and cleaned up waiting for paint. Gas tank and all lines are out now too. I’ve been spending a few hours each morning scrubbing the underside and framerails. I don’t hunk I’ve convinced myself that I don’t need to drop the frame although it’s really close and would be much easier to paint. I am going to paint the firewall since a color change is in the plans so no better time than now for that. Luckily my wife just kind of shakes her head when I talk about my plans for it😎
09-23-2021, 08:54 PM | #17 |
09-30-2021, 05:35 AM | #18 |
The term is " sensuous". Sensuous is already in there, then you might as well do all of the rest.
10-02-2021, 05:00 PM | #19 |
That’s awesome
10-20-2021, 10:48 AM | #20 |
Watch out!! That's how many frame-off restorations began!!
10-20-2021, 06:58 PM | #21 |
Yep. I talked myself out of pulling the frame. Took some convincing
10-29-2021, 07:45 AM | #22 |
At least you do not have many layers of a rusty onion to peel back.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
10-30-2021, 01:43 AM | #23 |
It has the normal rocker rust. Other than that not too bad. I hen I get the electrical set up in the garage I can start on that. All in all it’s not too bad though.
