Old 09-12-2021, 10:19 AM   #1
Hotcorner
Hotcorner's Avatar
Brake Lines to Master
I am installing Frank’s upgraded master cylinder and need to change the angles to the prop valve. Seems like I have plenty of line. Can these be re-bent with the spiral wire on them?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 09-12-2021, 12:39 PM   #2
Accelo
Accelo's Avatar
Re: Brake Lines to Master
Well the answer is maybe.
If you just need to go a short distance,and will not be adding a lot of bend, you may be able to bend them by hand. Connecting them to the block will sometimes help as there is no method to bend them close to the fitting unless they are attached. Sometimes one can slide the wire wrap out of the way and use a bender and then slide it back into position. The replacement lines Frank sells for this conversion are not even close so forget that option as you will be in the same predicament only with harder to deal with stainless lines.
Accelo is offline   Reply With Quote
Old 09-12-2021, 02:14 PM   #3
Hotcorner
Hotcorner's Avatar
I’ll give it a shot.
What’s the purpose of the wire wrapping?
1969 GMC K25
Old 09-12-2021, 02:32 PM   #4
HO455
Post Whore
HO455's Avatar
I believe it is for chaff protection.
Accelo has good information and the only thing I will add is that sometimes you can use an oversize bender on the spiral sections to help reshape the lines.
RIP Bob Parks.
Old 09-12-2021, 03:05 PM   #5
Getter-Done
Getter-Done's Avatar
That spiral spring is called Gravel Guard.
Link: https://www.amazon.com/dp/B015YGRG4C...mcd_asin_2_img
84 Chevy K-20
