upper steering column guts
I have been reading & searching for the last few hours on here trying to find the answers. Bought a supposedly "rebuilt" column & have had nothing but trouble. Replacing the OE steering wheel with a aftermarket Grant Classic and nothing seems to be going together quiet right. I thankfully kept the original '72 column and found this housing/bearing the opposite direction in each of them.
1. How is the bearing supposed to be positioned? 2. Also, am I missing a spacer that goes on the shaft? Was watching a Brothers video & it looks like a spacer on his & I don't have this on my current or old column. 2a. If there Is a missing spacer, does anybody happen to have dimensions of it so we can make one tonight without waiting days if ordered?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Re: upper steering column guts
See if this thread helps you (post 4 has a good diagram): https://www.67-72chevytrucks.com/vbo...d.php?t=630848
In your first pic, the bearing is on the wrong side.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 09-14-2021 at 03:44 PM. |
#3 | |
![]() ![]() Join Date: Jan 2005
Do you have a tilt column or non-tilt? The photos with the orange dash in the background are of a tilt column, so that might be why it looks different from yours.
Well then that would be it then, mine's non-tilt.
Perfect, you should have everything you need then
72 C10 lwb fleetside -stock 350/350 combo |
![]() Join Date: Apr 2010
In the 1st picture you have the bearing on the bottom and it should be on the top
