Old 09-21-2021, 08:56 PM   #1
gregbr
Senoir Member
gregbr's Avatar
TH350 / NP205 Cross member location
On my 67 4wd short bed with a 350, where should the TH350/NP205 cross member be located to put the transfer case shifter in the proper location?
Measurements and pics would be great...and advice.
My truck is a factory 4wd, factory V8, factory short bed. When I got the truck someone had swapped in a mid 70's 350, TH350, & NP203. So there are a couple extra bolt holes from all the swaps. I have a 205 and the original cross member set with skid plate from a 70-72 to put in.
I'd like to end up with the transfer case shifter in about the original position and have enough room at the engine & firewall for a HEI distributor.
Thanks.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 09-21-2021, 09:06 PM   #2
gregbr
Senoir Member
gregbr's Avatar
Re: TH350 / NP205 Cross member location
I looked through the assembly manual but didn't see anything helpful
Old 09-21-2021, 09:26 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
In 67 there was no 350/205 combo available only a 3speed/t221 and sm420/t221. Both of my trucks are sm465/205’s so I’m not much help otherwise.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 09-21-2021, 09:39 PM   #4
kwmech
What 57 said ^^ you will have to run with it and bolt everything in, clamp the cross member where it falls and use the holes in it as a template
Old 09-21-2021, 10:54 PM   #5
Richard
My 72 SWB truck is (was) a 350/350. Will see if I can get you a measurement from a common point on the frame. Maybe shackle hanger rivet or something like that.
Richard
Old 09-22-2021, 12:14 AM   #6
57taskforce
All about them K’s
If I remember right I think my ‘72 has two sets of holes where the transfer case crosmember bolts up. I would assume since mine is a factory 465 truck that the opposite set of holes would be for the TH350. I too will see if I can look into it more tomorrow.
Tyler
Old 09-22-2021, 12:43 PM   #7
gregbr
Senoir Member
gregbr's Avatar
Yes, I know what was original but long gone. Hopefully the measurements from another year with work.
Thanks to all
Old 09-22-2021, 06:39 PM   #8
landarts
landarts
HEI distributor can work but will be really close on the firewall. Possibly look at an HEI with small cap, and separate coil pack. It will make things much easier.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 09-22-2021, 08:20 PM   #9
Richard
Here are a couple pics. Measurement is from center of rear rivet holding shackle hanger on. A little blurry, awkward taking shots under the truck holding the tape and phone. Hope they help.
Richard
Old 09-22-2021, 08:35 PM   #10
kwmech
you're gonna need some good drill bits
Old 09-23-2021, 02:38 AM   #11
Richard
These frames are not that hard. Have drilled a couple bolt holes in mine, 3/8" up to 1 1/2". A bit less than $10 should last 8 3/8" holes. That said the upper frame holes can be difficult with the body on. Solutions I have found are a real long drill bit if holes align, can be costly. Even the stubby bits available are to long and have to be cut down to use a 90 degree drill. Mostly I use a 1/4" Milwaukee 90 adapter and short hex bits that I step up twice to do the upper frame holes.
Richard
Old 09-23-2021, 08:56 PM   #12
gregbr
Senoir Member
gregbr's Avatar
Thanks to landarts, I haven't seen the small cap HEI. Will look into that. Easier than moving everything an inch for some clearance.
Thanks Richard, the measurements will be a big help laying it out.
Old 09-23-2021, 10:33 PM   #13
landarts
landarts
Here you go
Look at this on eBay
https://www.ebay.com/itm/CHEVY-SMALL...-127632-2357-0
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 09-28-2021, 09:50 PM   #14
gregbr
Senoir Member
gregbr's Avatar
Thanks landarts, neat dizzy setup.
