Old 09-22-2021, 10:28 PM   #1
HeloCrewChief
HeloCrewChief's Avatar
4x4 valve cover grommet sizes
Does anyone have the valve cover grommets sizes handy? I’m having a heck of a time finding the one for the right rear air to air cleaner and the oil filler tube. Haven’t been able to find some at the local auto parts store.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 09-22-2021, 10:52 PM   #2
geunther
geunther's Avatar
Re: 4x4 valve cover grommet sizes
I believe the part number is 3989344 at least for the right rear. I think you can find the size if you look up that part. I found an NOS box of them (4) but I think there are others out there that will work.
If you can't find any, I will have an extra.
Not the ones I bought, but some others on eBay.
geunther is offline   Reply With Quote
Old 09-23-2021, 03:08 AM   #3
tj1970cst
I think I found some on Amazon. Might have bought 4 and returned 2 with the free returns feature.
tj1970cst is offline   Reply With Quote
Old 09-27-2021, 08:13 AM   #4
HeloCrewChief
For anyone that does a search in the future, I’ve attached pictures of the three correct grommets you will need for 4x4 valve covers. I just got the installed and everything fit.
Old 09-27-2021, 09:29 AM   #5
geezer#99
geezer#99's Avatar
It might help if you explain the difference between normal and 4x4 grommets.
Is there a difference?
Could save someone getting the wrong ones.
Old 09-27-2021, 09:40 AM   #6
Accelo
Accelo's Avatar
The large one is the oil fill tube grommet.
PCV grommet for the left side.
The last one has to be the tube for the air intake from the air cleaner on the right side.
Accelo is offline   Reply With Quote
Old 09-27-2021, 10:51 AM   #7
HeloCrewChief
No offense but, I thought I already helped quite a bit. Just pulled 3, 14 hour shifts so this is about all I’m good for! Pretty obvious the differences between 2wd and 4wd engine compartments. Anyway, still hope this helps someone.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 09-27-2021, 11:19 AM   #8
CS1972
CS1972's Avatar
HeloCrewChief..............good information, will save me the effort of figuring it all out.
Thanks!
Ron
1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White
CS1972 is offline   Reply With Quote
Old 09-27-2021, 01:36 PM   #9
Classic Bowties
Always on the hunt...
For others searching and future reference, we have a long running f/s thread (link below) on the parts board for the optional OE 71-72 small block oil filler extension tubes and matching GM NOS tube to valve cover grommets. Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=818966
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our paypal account & info has been changed as of Jan. 2022. Thanks...
Classic Bowties is offline   Reply With Quote
Old 09-27-2021, 03:41 PM   #10
k29349
I was also wondering why there would be a difference.
k29349 is offline   Reply With Quote
Old 09-27-2021, 08:39 PM   #11
Accelo
Accelo's Avatar
I am not sure of this but maybe the non-for wheel drive had the a oil fill plugs in the valve cover and didn't include the extended tube?
Only speculation. Someone here know the answer.
Old 09-27-2021, 09:44 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The extended SB oil fill tube isn’t specific to 4wds. I believe it’s on AC equipped SBs and power brake equipped trucks. The NOS power brake unit I used for my Blazer had the oil fill tube in the kit.
Old 09-28-2021, 01:11 AM   #13
tj1970cst
My personal best is 14 16hr shifts never more than 8hrs off. Hit all three shifts before it was done.
Old 09-29-2021, 08:20 PM   #14
HeloCrewChief
That’s cute…you have no idea which makes me laugh.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 09-30-2021, 08:22 AM   #15
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I wished mine had the extended oil fill tube, it is a little bit of a pain to put oil in (2 Wheel 72 350, AC, Power brakes). I thought about adding it but I image the grommet wouldn't properly seal as my cover is for a cap.
My truck seems to have been very original and of all the things to go missing, why would the cover be replaced for a cap version (I assume extended oil fill tube covers have a different hole for the grommet and not a cap). Then again, no telling what has happen to the truck over its lifetime!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-30-2021, 10:56 AM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The extension uses the same OE cap labeled "oil" that's in place on the valve cover. After engine assembly this cap was painted orange with the rest of the motor. When the extension was used this orange cap was reused atop the extension. Here's an example on a 50k mi 72 350 pulled from a K20 Suburban for use on my K20: http://67-72chevytrucks.com/vboard/s...56&postcount=3
Old 09-30-2021, 11:20 AM   #17
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Question Re: 4x4 valve cover grommet sizes
1st, sorry for hijacking this thread and 2nd, sorry if I am being stupid. I am very interested in this oil fill tube. I almost bought a setup but then decided not to because I assumed it would not work with the hole.
Here is a photo where my twist cap goes into. The hole is notched, so the cap twists/locks. I assumed if I tried a oil riser tube, the required grommet couldn't seal because of the notches/lip in the valve cover?
Thoughts @DeadheadNM or am I over thinking this hole?
Richard
Old 09-30-2021, 11:34 AM   #18
geunther
geunther's Avatar
Is that maybe a newer than 72 valve cover or something specific to 4x4? My originals do not have the notching, just clean holes.
Old 09-30-2021, 11:37 AM   #19
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Could be but it is what came with the truck when I got it. Though when the engine was rebuilt the guys where 95% sure it was factory and had never been opened up. But that doesn't rule out the covers being replaced in its lifespan.
Richard
Old 09-30-2021, 11:45 AM   #20
geunther
geunther's Avatar
I think the grommets are used with a different hole design.
Old 09-30-2021, 12:02 PM   #21
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
yep, agreed or that makes the most sense to me!
Richard
