Old 09-25-2021, 03:01 PM   #1
69BUCKET
72 c10 lowered leaf spring struck
Cleaning up frame for lowering project, but kept it with leaf springs. Is the shock location ok for lowering it with 5" leaf springs?
69BUCKET is offline   Reply With Quote
Old 09-25-2021, 03:19 PM   #2
Mike C
Mike C's Avatar
Re: 72 c10 lowered leaf spring struck
There is a second hole in the shock mount that is in a more vertical position that is better IMO. I drilled the upper hole out and mounted new shock hardware in that. My truck has a rear flip kit that netted 7” of drop. I used stock front shocks in the rear which has worked well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-25-2021, 03:54 PM   #3
69BUCKET
Did you cut off old shock mount as well? Any pics of how low your truck sits? I didn't want it to low but curious as to what size tire you run om rear?
Old 09-26-2021, 04:21 PM   #4
Mike C
Mike C's Avatar
I removed the old shock mount. I don’t remember if it needed cutting or just unbolting? I want to say I just unbolted it and reused it in the second hole? I’ve had a couple of other trucks I have worked on in the mean time and may be mixing some of the shock mount hardware up.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-27-2021, 09:08 PM   #5
Ben IV
I also used the additional hole in the shock bracket but made my own lower mount to run the original shocks.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 09-28-2021, 11:00 AM   #6
Mike C
Mike C's Avatar
Nice work. With the original mount in place, front shocks were the perfect length. And I was hoping the fronts had more dampening than the original rears. Do they? Don’t know but am happy with the results, I’m running KYB GR2 shocks.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-10-2021, 02:19 PM   #7
Primered_69
Primered_69's Avatar
i swapped the mounts sides and it finished up a good angle for the shocks
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 10-16-2021, 11:54 PM   #8
69BUCKET
Parts all painted and ready to go back in...started wondering about pinion angle. I have 5" lowering leaf pack and only found a shackle with 1 and 2 inch lowering options. So rear will be down 6". I did put in all new u-joints on 2-piece driveshaft as well.
Will i have issues with pinion angle and/or length of driveline?
Old 10-17-2021, 10:08 PM   #9
Mike C
Mike C's Avatar
That will just depend on your truck and the spring pack. The flip kit pinion angle is adjustable. You can buy shims if you need to adjust yours. Once you get it together, you can measure it.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-17-2021, 10:31 PM   #10
69BUCKET
I didn't do a flip kit. Just 5" leaf pack and the shackles which i have at 1" option right now. I haven't looked into it yet, any idea what proper angle should be?
Old 10-17-2021, 10:32 PM   #11
69BUCKET
Couple more things to button up...
Old 10-18-2021, 10:06 PM   #12
Mike C
Mike C's Avatar
My apologies my post wasn’t clear. On my truck the flip kit allowed the pinion angle to be adjusted. On yours, you will have to get it on the ground and measure to find out if you need to correct it or not.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-18-2021, 10:47 PM   #13
69BUCKET
Rear is done...pinion angle looks fine...drove it around the block, previous vibration it had is gone.
Old 10-23-2021, 01:17 PM   #14
69BUCKET
Update on rear...
Used the 1 or 2" lowering shackle on 2" option
had to cut one of the bed support channels to let leaf spring clear. Bed of floor clears the shackle. 7" total drop on rear, front going down 4" with spindle and springs.
Old 10-23-2021, 01:20 PM   #15
69BUCKET
Old 10-23-2021, 09:12 PM   #16
Mike C
Mike C's Avatar
Nice. I did the leaf flip on mine I think we discussed above and it netted 7” of drop. I have some ECE drop rear shackle, but 7” is low enough that frame interference starts to loom.
I did disc conversion 2 1/2” drop spindles and 2” drop springs on mine. Very happy with how it looks and rides.
44 Willys MB
52 M38A1
64 Corvette Coupe
