09-25-2021, 10:21 PM | #1 |
newly minted old timer
First start up l96 with 6l90
Gota lot these moments. I was surprised it started right up on first turn.
Also have to say the dakota digital dash sure makes things easy! Now I have to put it I the long horn https://youtu.be/5odAiebFdmI https://youtu.be/-vk18OphqwI
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban Last edited by mtdave2; 09-25-2021 at 10:36 PM. |
09-25-2021, 10:52 PM | #2 |
Re: First start up l96 with 6l90
Congrats, I love your engine run stand!
09-26-2021, 11:46 AM | #3 |
Brilliant! I'm rocking the exact same setup (except for 4X4). Very excited for first startup...keep it up!
09-26-2021, 11:29 PM | #4 |
Post Whore
Nice setup
09-28-2021, 10:45 AM | #5 |
thanks, guess its time to stuff it into the longhorn now. ran the crap out of it and everything is working perfectly. it is fun to play with a motor on a stand like this. ones i have the old motor out ill stick it on the stand and try to figure out wtf is wrong with it.
gota love toys huh?
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
09-28-2021, 11:37 AM | #6 |
09-28-2021, 11:05 PM | #7 |
Are you using the factory torque converter? I've heard the TC is the weak link in those transmissions, and that an improved aftermarket unit is highly recommended.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-29-2021, 10:19 AM | #8 |
yeah, i have not touched it. the motor and trans have 9k miles on them so i was going to leave everything alone. though i had not heard of the TC issue.
09-29-2021, 01:57 PM | #9 | |
I haven't personally looked into it much myself. I specifically chose a nv4500 over a 6L80e, in case that shows you where my allegiance lies!
10-07-2021, 02:09 PM | #10 |
Did you use the E78 ECU and wiring harness that came with the motor? I have the same setup and was thinking about going with a PSI ECU and harness.
Love the valve covers, What brand are they? |
10-08-2021, 09:34 AM | #11 |
after lots of debate and talking with knowledgeable people i did not use the 78. there was no advantage to doing so, and lots of downsides. so i had speartech make me a harness with the 38.
10-08-2021, 09:35 AM | #12 |
10-08-2021, 11:37 AM | #13 |
Thanks. I was talking with PSI about doing the same thing for my L96 and 6l90E. My donor was from a 2019 Isuzu NPR and was told the E78 is not friendly from the Isuzu.
What did Speartech charge you? Did they program the TCU also? |
10-09-2021, 09:06 AM | #14 |
what gaguges are those?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-11-2021, 10:29 AM | #15 | |
I did send in the tcu for them to program as well.
10-11-2021, 10:31 AM | #16 |
