10-04-2021, 05:12 PM | #1 |
Guest
Posts: n/a
Where to put new driver's side junction post
I'm getting into tidying up some wiring and I'm going to install a junction post on the left side. Between the washer bottle and core support maybe, pretty much straight across from the junction by the battery , not a whole bunch of room there. Or on the core support on that vertical piece left of the rad.
What do you guys think? I'll also be upgrading the wiring from the alternator to this new post and across to the battery. My headlight relays are in that box on the core support so they'd get power from the new post , too |
10-04-2021, 06:05 PM | #2 |
Re: Where to put new driver's side junction post
When I did my LS swap and switched the battery from the right to left side, I added a new junction block to the left fender in the same spot it resided on the right fender.
10-04-2021, 06:15 PM | #3 |
Guest
Posts: n/a
I was looking at that , it just seems a bit tight forward of the washer fluid bottle. It would fit there, but you'd just want to be really sure you disconnected the battery before messing with it
10-05-2021, 01:12 AM | #4 |
I just installed a two post junction block from a 1980's Gm truck on the radiator support behind the headlights, sorta. Everything related to that junction and it's general area is under construction right now, so when I went a took a picture right now, it really looks like a horrible mess--which is a bad way of advertising on how to clean and organize your wiring. So I decided not to post the picture....
EDIT 2: I basically mounted the junction right where the little hole is directly above the voltage regulator(pic borrowed from VetteVet) https://67-72chevytrucks.com/vboard/...6&d=1379551047 Last edited by jumpsoffrock; 10-05-2021 at 01:37 AM. Reason: I'm not good at trucks |
10-05-2021, 12:01 PM | #5 |
Guest
Posts: n/a
Thanks, I'll check that out
That small hole is one of the ones I used to mount my relay box, and another one a few inches above it Last edited by jeff74; 10-05-2021 at 12:22 PM. Reason: Additional info |
10-05-2021, 03:02 PM | #6 |
Post Whore
Here is a photo of how I mounted mine. I used a marine insulated post.
For more information on the rewire see the link scroll to post 467. https://67-72chevytrucks.com/vboard/...698377&page=19
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-05-2021, 08:09 PM | #7 | |
Guest
Posts: n/a
I'll make up my mind eventually Thanks |
10-06-2021, 01:09 PM | #8 |
Post Whore
At the time I had considered mounting the post to a piece of 3/8" plastic plate and mounting the plate to the bottom of triangular bracket just forward putting everything out of sight. It wouldn't have been much work but, it would have made future access to the post more difficult so I decided against it.
