Old 10-17-2021, 04:25 PM   #1
wazzabie
leaf spring question
This bolt has gone bad. I think it is also contain in a metal tube. Does some sell this part? Also if I unbolt this will it be dangerous? Do I need to clamp the leaf springs to reduce it going un sprung?
wazzabie is offline   Reply With Quote
Old 10-17-2021, 06:10 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: leaf spring question
Any spring shop should have a replacement or im sure you could replace the bolt with a grade 8 from Home depot or Lowes.. Lowes also sells a spacer you could adapt to fit
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 10-17-2021, 07:40 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
order a new one on ebay or a leaf spring seller near you.
Or get 1 from a u-pull-it
Old 10-17-2021, 07:48 PM   #4
sweetk30
sweetk30's Avatar
Its to hold the leafs from fanning out .
You can pull it no problem . There no crazy special bolt so hardware store stuff is fine .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-23-2021, 05:30 PM   #5
kglowacky
before you remove that center bolt put a c clamp on it so once the bolt is removed you can release the spring pressure slowly. Its isn't dangerous like a coil spring but it does have a little pressure on it. The new correct bolt will be longer then the one you are removing. Once you tighten it up you the cut off the extra length.
kglowacky is offline   Reply With Quote
Old 10-23-2021, 08:49 PM   #6
sweetk30
sweetk30's Avatar
He is NOT asking about the center pin .
But good safety info you posted .
Old 10-24-2021, 06:29 AM   #7
Hammered 77
Hammered 77's Avatar
Check out Beattie Spring.
Rick
Hammered 77 is offline   Reply With Quote
