10-20-2021, 06:36 PM | #1 |
I6 will idle all day, dies with gas
On my all original 72 with the inline 6 and single barrel Rochester it will start and idle all day long no problem but as soon as start giving it throttle it immediately dies. Main jet clogged? Or am I missing something entirely?
Posted via Mobile Device |
10-20-2021, 07:38 PM | #2 | |
Re: I6 will idle all day, dies with gas
If the pump shot is there, and the problem persists, I would check the fuel filter, and fuel pressure. If all good, then open the carb up. |
10-20-2021, 10:32 PM | #3 |
To add to the other checks, How old are the fuel lines and the sock inside the fuel tank?
10-23-2021, 10:08 PM | #4 |
It was the fuel pump, very shortly after I posted about problem it started leaking fuel. Put new pump on and works perfectly now
10-24-2021, 10:01 PM | #5 | |
However, watch that new fuel pump. I've had several go bad on me. One lasted a whole hundred miles before it was spraying gas all over the underside of my engine. Two possibilities: 1] Cheezy Chinese copy of a real fuel pump, but made with cheapest possible components [and priced like premium]. Or 2] New gas with ethanol additives eating thru rubber parts in diaphragm. So keep an eye on it.
10-26-2021, 08:48 AM | #6 | |
