10-27-2021, 06:37 PM | #1 |
67 C10 want to do coil over conversion.. bye bye air bags
Does anyone know of a good coil over conversion for the front that is also 1" narrower or more than stock? I cant seem to find one. They are all either stock width or they are not coilovers.
PS: I have a big block. I want to use stock frame/crossmember |
10-28-2021, 04:38 PM | #2 |
Re: 67 C10 want to do coil over conversion.. bye bye air bags
I've never seen C/O based a-arms that were not part of a larger 'kit'.
If you want narrowed arms only, you'll need to visit the usual suspects/sources for stock x-member arms (Porterbuilt, GSI, Choppin Block, etc). The lower C/O mount is just a matter of finding/making a bracket that can be welded to a plate & bolts in where an air bag would have been originally mounted. I have C/O's bolted in where air bags would for my front set-up. I'm using an aftermarket x-member but there is no need for specific C/O arms depending how you set it up. For your needs, check out this build. He modded stuff & used the Ridetech/POL type upper bracket arrangment w/a modded OE x-member.... http://67-72chevytrucks.com/vboard/s...d.php?t=799484
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-28-2021 at 04:46 PM. |
10-28-2021, 07:12 PM | #3 |
Post Whore
I would repost in the suspension section. Several of the vendors as well many suspension guru's hang there and at least one person should know the answer to your question.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-29-2021, 12:15 PM | #4 |
I did post it over there.. no one responded except for a guy that said i shouldnt double post lol
10-29-2021, 12:16 PM | #5 |
I appreciate it! with my offset on my wheels... i have zero room in that front end by the fender. seems like coil spring is the only option.. i just really like the adjustablity of a coilover.
10-29-2021, 12:37 PM | #6 |
Call no limit engineering. Rob and the guys over there are top notch and very knowledgeable. I have his whole coil over and crossmember set up to go on my truck.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
10-29-2021, 03:26 PM | #7 | |
If a coil fits, a bag will. Narrowed a-arms for bags are available. A C/O is just a couple brackets away from working where a bag was.
11-01-2021, 12:39 PM | #8 |
I have bags now... i really want to do coil overs for adjustability.. tired of dealing with the airbag set up.
11-01-2021, 01:25 PM | #9 |
What SCOTI is trying to say that there is nothing special about the a-arms in most coilover "kits". You just need a way to bolt in the coilovers to the lower a-arm and frame. A one inch narrowed front end is kind custom territory for a coilover (the general idea of a coilover front end is to improve suspension kinematics versus narrowing the location of the ball joint to replicate an articulating airbag setup), which may mean that adapting what you already have may make sense, or call up a company that makes their own parts that will work with your application and their design.
11-01-2021, 01:35 PM | #10 | |
The specific point was one can adapt C/O's fairly easy using a narrowed air-bag style (plated) lower a-arm which are readily available. You just need to make a lower mount that bolts in where the bag was. You'll also need upper arms that can clear the C/O as well & fab an upper bracket.
11-01-2021, 01:52 PM | #11 | |
I guess time and $ will tell. |
11-01-2021, 01:58 PM | #12 |
PB makes some nice parts.
11-02-2021, 10:09 AM | #13 |
