10-29-2021, 12:07 AM | #1 |
Any timing experts out there that can explain some some timing paremeters
I was hoping someone on the forum could help explain the different timing parameters and maybe some base numbers I can start with on my new distributor.
I just installed the Progression Distributor and I can now control timing on the fly or make different timing tables for different driving. I know just your standard intial timing and all in, just the basics but could use some help explaining the different values with this new distributor so I am able to get the most out of it. Here is the different tables I need to populated. I would like to have a table for cruising around town and being able to get into the throttle a little bit and also for highway driving. Any help with explaining the different numbers would be awesome. I am trying to research as much as I can but can not get explanations for some of the values and I am kinda lost So far with just the auto set up my truck is running way smoother, I have not driven it yet, waiting until I get the gear vendors unit installed. Thanks everyone.
1972/Sierra Grande k2500 / 383 / th350 with Gear Vendors / 4.11 / 4" lift with 35s / Eaton Rear Axle |
10-29-2021, 10:05 AM | #2 |
Post Whore
Re: Any timing experts out there that can explain some some timing paremeters
In order for us to make informed recommendations we need detailed information on your truck.
Carburetor and intake Cylinder head type and combustion chamber size Compression ratio Camshaft specifications and lifters installed Transmission Rear end ratio Rear tire size Now if you don't know the answers to all of these some assumptions can be made as long as timing is kept on the conservative side to prevent engine damage. Here is an article covering the basics. https://www.onallcylinders.com/2020/...to-make-power/ And if you really want to dive down the rabbit hole. https://etrr.springeropen.com/articl...544-013-0099-8
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-29-2021, 10:20 AM | #3 |
I have this system also. Nice thing is you can save multiple tables and switch on the fly, also edit specific rpm/advance cells on the fly and then save the changes.
I have a SP350/357 GM crate motor that has a mild cam with a very tight LSA at 108. I set idle in park at 850, 15 degrees idle, 32 total at 3000 and aggressive mode. Since I have a 4 speed OD auto trans and with 4.10 gears I'm just at 2000 at 65-70 mph I tuned the vac advance parameters very agressive with 15 total advance starting at 70 full at 50. Now at cruise I'm at about 40 total advance but even light throttle drops it to the mid to high 20 range. Its a trial and error thing, every engine will be different. Here is a image of my timing table. I'm also open to comments
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
10-29-2021, 11:22 AM | #4 | |
Carb: Edelbrock AVS 2 / 650 cfm/ performer intake/ 2" spacer Cylinder heads: fuelie heads/ 72 cc chamber/ Valves: 1.94 and 2.02 Lifters: 1.52 Compression: 11:1 ( has domed pistons) Transmission: TH350 with gear vendors overdrive Rear end: 4.11 TIRE: 35 inch I'm not sure on the cam shaft and the compression is just what I got when I looked up my heads, I have not taken the cam out though. I bought my truck the owner rebuilt the engine to a 383 stroker. Sorry I can get some of the other specific details. Thanks again for your help.
10-29-2021, 11:47 AM | #5 | |
How long have you had yours? Really like mine so far but don't have any road time yet, feels like it's built really well. Thanks again.
10-29-2021, 05:06 PM | #6 | |
10-29-2021, 05:12 PM | #7 | |
10-30-2021, 09:26 PM | #8 |
So I finally got my truck out in the road today and I must say it's like a completely different truck. So much more smooth and responsive. For fun I put in your values for my truck and it was a rocket from 1st to 2nd. It lagged a little going into 3rd but you should have seen my face lol.... I very much look forward to playing with this !! Thanks for the help.
11-01-2021, 02:19 AM | #9 |
You need to get a manifold vacuum number at idle, and off idle so you can set the vacuum advance parameters. At idle, you want around 15-20 degrees of “vacuum advance” for best efficiency. This will lower EGT and engine temps.
11:1 ? You would need a pretty large overlap cam to bleed that down to something manageable on pump gas. Big cams need more idle timing due to intake air being diluted with exhaust gas. |
11-01-2021, 01:08 PM | #10 |
Mr. Cheyenne
Not sure how I missed this thread, I just got mine installed last weekend (love it).
I am just not sure what to do with the below, so I haven't even tried to touch them. Max Vacuum Adv Start Vacuum Adv Max Vacuum Adv At After a controlled test drive, using the App's Vacuum gauge to help me keep my foot inline, I got 18.5 MPG on mixed highway/city! Though before trying to mess with anything the truck started up and idled better than it ever had in the past. My Engine is more or less stock with a mild cam (really don't know its model/stats). 72 SBC with 993 heads with 76cc chambers, 72 Qjet (tuned for a 68 model by Cliff High Performance), Th350, 3.08 Rear End, and 235/75 R15 tires all around. Cliff says my engine is likely lower compression because of the “builder” 350 pistons & head gaskets. Something about messing up the "quench" and probably down around 7.5-7.7 to 1 or so. For what it is worth, here is my current settings.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
11-01-2021, 01:47 PM | #11 |
Rich72C10 can you change the Kpa unit to Inches of Mercury? Hg”
There is another thread going “Timing” and someone posted an article by the Late John Hinckley. The article is considered the Bible as far as timing and dist. Function. You need to have more then 8* of vacuum advance. If your engine idles at say 16”Hg, you need to have the vac advance full in at 14” (two inch rule). A good start would be (assuming 16” idle vacuum) 20* advance at 14” 18* advance at 13” 16* advance at 12” 14* advance at 11” 12* advance at 10” 10* advance at 9” 8* advance at 8” 6* advance at 7” 4* advance at 6” 2* advance at 5” 1* advance at 4” This is very important, and highly misunderstood. Burned headers, heat soaked starters, overheating engines, vapor lock, poor fuel economy, sluggish part throttle response are all the symptoms of not having an active vacuum advance and not having it set right. It appears you have the advance backwards, you want it to start at 4”-6” (the sooner the better as the engine will allow) and max out at 14” Kpa to Hg 13.5 Kpa = 4” Hg This will be the START VACUUM ADVANCE 54 Kpa = 16” Hg. THIS WILL BE THE MAX VACUUM ADVANCE A cam spec and manifold vacuum reading at idle will tell a lot about your valve timing and what your engine timing should be. Last edited by 1970-CST; 11-01-2021 at 02:07 PM. |
11-01-2021, 01:57 PM | #12 |
Mr. Cheyenne
no, it doesn't have an option to change from KPa to Hg. Though I am not sure which bit would get "20*" at 14 degrees initial. Which I do happen to have a solid 16hg at idle.
11-01-2021, 02:21 PM | #13 | |
https://www.convertunits.com/from/kPa/to/in+Hg If you have solid 16” at idle, you want full vacuum advance at 14”, which equals 47.4 Kpa. And the start at 4” or 13.5 Kpa. I would set the following MAX VACUUM ADVANCE = 20* START VACUUM ADVANCE = 13.5 Kpa MAX VACUUM ADVANCE AT = 47.4 Kpa. This is telling the computer to do this: Start adding vacuum advance at 4” and add up to 20* of spark advance, all in by 14” Hg to respect the 2 inch rule. If it knocks or pings, back the 20* down 2* at a time until it doesn’t. |
11-01-2021, 02:28 PM | #14 |
Mr. Cheyenne
well, can only use whole numbers in the app and for "Start Vacuum Advance at" can't be less than 20 (must be a value between 20 and 101).
so that is a bust to try out. Though I didn't put in the values backwards - that is what the app started with. I haven't messed those Advanced timing values at all.
11-01-2021, 02:32 PM | #15 | |
Vacuum advance is only a factor for idle, low load cruising, and trailing throttle. It is meant to decrease its spark advance as engine vacuum drops, not increase. When you mash the gas pedal down, vacuum goes to near zero, and all the vac adv should go away, incrementally by 4-6” Hg or the engine would ping and knock. Inversely, as the engine gains RPM (gas pedal still mashed) manifold vacuum will begin to rise, and vac adv slowly added back in. 90% of our driving is part throttle cruising, where we want the vac adv for engine efficiency, fuel economy, etc. Last edited by 1970-CST; 11-01-2021 at 02:44 PM. |
11-01-2021, 02:41 PM | #16 |
Mr. Cheyenne
I have looked at a few screen captures (other users that have posted) and videos on YouTube - the three settings we are talking about are pretty much the same as my screen shot. Nothing really talks about changing these values at all.
Heck, the last thing I want to do is blow a rod out the side of my engine ha!
11-01-2021, 02:47 PM | #17 | |
I would change it. Here is John Hinckley article. http://www.camaros.org/pdf/timing101.pdf The short of it is GM used the vac adv schedule as described in my post, then changed to a degraded / less optimum “ported system” to comply with the emissions standards in the late 60’s. Last edited by 1970-CST; 11-01-2021 at 03:03 PM. |
11-01-2021, 03:22 PM | #18 |
Mr. Cheyenne
Well, the app won't let you do any of these settings.
1. First the app said I couldn't have more than 50 total timing. So I played RPM/Vacuum Max numbers to get 50 total. 2. Then the apps reported "Start Vacuum Advance At Must be Greater than Max Vacuum Advance At". So the app isn't having any of these settings.
11-01-2021, 06:40 PM | #19 |
I think some of the confusion is in how progression measures the vacuum pressures. The KPa readings are absolute pressure readings, total barometric pressure (std atmosphere is 101.325 KPa or 29.92" Hg) minus the manifold vacuum.
So in the example screenshot provided, the vacuum advance goes from idle at 20 KPa absolute or about 6" Hg absolute or about 24" Hg Vacuum. Similarly the 80KPa absolute should be about 24" Hg absolute or 6"Hg vacuum. Here's a review with a small explanation that might prove helpful: https://board.moparts.org/ubbthreads...al-review.html
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
11-01-2021, 07:33 PM | #20 |
Lots of good info here, thank you. I really had no idea how vacuum advance really worked, and still really don't. I read two of the Hinckley articles and since my engine makes about 10" of vacuum at idle, I am going to try adding 12 degrees of vacuum advance. My engine has always seemed rather sluggish and I wonder if it was because the vacuum advance was low. I run an Edelbrock Pro Flo 4 system too.
11-01-2021, 08:22 PM | #21 | |
11-01-2021, 08:32 PM | #22 |
Mr. Cheyenne
gee, glad we got that sorted out! I suppose I could have said "its a MAP sensor" does that make a difference?
11-01-2021, 08:35 PM | #23 | |
For discussion purposes, that engine (327/365hp 30-30 cam) idles at 1200 RPM, and setting base timing is near impossible, as the mechanical fly weights begin to add centrifugal advance around 700 rpm, lower then engine idles. So setting 10* initial timing was deceiving, as some of that was mechanical. In this case, I unhook the vacuum adv hose, and rev the engine until no more advance is added by the fly weights, in this case that was 2450 RPM. So at 2500 RPM I would move the dist. to set 38* advance. If I set it at idle, I was leaving 6* of timing on the table, as the fly weights were contributing to the timing at idle. So setting 10* on the tab, was actually 4* base timing. When optimizing for performance, 6* is a HUGE amount. What is your Idle RPM? Timing is everything, and all the tuning and widgets to make HP are worthless unless you can optimize the timing map for your particular setup. One needs to remember that “ported” vac adv, and low initial timing was a bandaid to get the engine across the emissions finish line. It was FAR from optimum. |
11-01-2021, 09:00 PM | #24 |
If you look at the timing map I posed above, you'll see 100 Kpa is 0 inches of vac and it goes inversely. The top few rows are pretty much full throttle and the bottom is high vacuum at deceleration. So at start at 80 is fairly low vac and 20 is very high vac. Its confusing I know.
11-01-2021, 10:13 PM | #25 | |
