10-29-2021, 11:50 AM | #1 |
C10 LS swap driveshaft
Time to make this purchase! What are you guys using for driveshaft source? My truck is 4.5 inches lowered in the front and 5 in the back.... going to do the measurements for proper length this weekend.... just got coil overs installed. Is there a stock truck option? Any help will be greatly appreciated.
1989 5.0 LX Coupe 1989 Saleen #243 1969 C-10 Fleetside 1966 Mustang Coupe GT 1965 Fastback Mustang 1951 F1 Truck |
10-30-2021, 02:47 PM | #2 |
Re: C10 LS swap driveshaft
I got the correct yoke and rear flange and took it to a driveshaft shop and they made me one for about 300. pretty easy.
10-30-2021, 04:38 PM | #3 |
I would up grade to 1350 u-joints if you are going to run a higher horse power LS.
10-31-2021, 10:51 AM | #4 |
I had a single piece, 3.5” diameter driveshaft made for my build (it was right at 69”). LS u-joints are 1350, but the rear axle yoke is a 1310. I used a 1350/1310 u-joint at the rear. Note my truck is a longbed
10-31-2021, 11:02 AM | #5 |
With my swap I used a 2003 Tahoe two wheel drive 5.3 with 4L60E. I used the original c10 V8 motor mount perches and motor mounts and mounted them in the 6-cylinder mount frame/crossmember location (had to drill a hole in the crossmember for the lower mounting bolts). I used the LS Swap Motor Mounts Adapter Plates that allowed me enough adjustability to use the Tahoe drive shaft. I swapped out the rear U-joint to a 1310 to 1344 combination U-joint. I have approximately 3/4" trans to yoke play. A lot cheaper than having a new drive shaft made.
11-01-2021, 12:10 PM | #6 |
For my 65 swb with 5.3 4L60e swap I snooped the driveshaft rack at my local wreckers and ended up with a 3 1/2" driveshaft from a 2002 F150 2wd 5.4l 139" wheelbase truck. The front yoke on the shaft matched the 4L60e slip yoke. I cut the rear off and had a weld in yoke put in the back. It was just long enough.
