Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 11-03-2021, 02:03 PM   #1
Warrens69GMC
Warrens69GMC's Avatar
S10 fuel pump cutout
While i recommend pulling the bed, some have asked for measurements for a proper cut.
Pictures speak volumes
Regular Cab, short bed
cut 14" to 22" from driver side wall
Old 11-03-2021, 05:36 PM   #2
Bigdually
Re: S10 fuel pump cutout
Great info! Thanks!
While pulling the bed used to be no big deal, I don't have the room I used to when I was working in dad's shop. As long as one can fix the hole properly, this makes a job that once was a real chore a pretty easy process. I'm sure there are lots of other guys in the same boat I am with not much time, help, or room to pull a bed, but can cut a hole like nobody's business
2.5 Ton Pickup Build:
1989 GMC 6000 Pickup/Toy Conversion
Bigdually is offline   Reply With Quote
Old 11-03-2021, 11:23 PM   #3
Just call me Sean
Just call me Sean's Avatar
Pull the bed? Drop the tank.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-04-2021, 11:51 AM   #4
Bigdually
My brain defaults to the bed, pulling those 6 bolts and wrangling a good helper always was my preferred method vs jacking up the truck, then half dropping a 100 pound tank full of gas after you broke the straps then fanagling the hoses and wires loose before you break something.
I'll never understand why more vehicles didn't come with the fuel pump access panel that some cars had under the rear seat.
