11-06-2021, 05:46 PM | #1 |
Need a seal NP205
I am in need of the seal that goes into the speedo sleeve for a NP205 for my 70 4x4. If any knows part number or that has an extra.
Thanks Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
11-06-2021, 06:02 PM | #2 |
Re: Need a seal NP205
Found this on another site, AC DELCO #326561
11-06-2021, 06:51 PM | #3 |
All about them K’s
This might help, there’s another link in this thread that might be useful as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=715463
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-06-2021, 07:39 PM | #4 |
I suspect it's the same seal a used on the automatics?
There are two different sizes there. If you post the ID and OD I'll look. |
11-06-2021, 08:38 PM | #5 |
I did a search and did not come up with any thing relevant like you Gents. I did find the AC Delco one but it was out of stock or discontinued.
Accelo I believe they are the same as Auto's. The one pictured is from my auto. Thanks Ron
11-06-2021, 09:20 PM | #6 |
Here's another seal that looks like the one in the other thread.
https://www.offroaddesign.com/gm-np2...eter-seal.html |
11-07-2021, 01:02 AM | #7 |
"The one pictured is from my auto."
I meant when the speedometer is run from the transmission not the transfer case. Sorry, I can't help without measurements. |
11-07-2021, 11:42 AM | #8 |
the shaft of the gear where it will sit in seal(rubber)is 13/32"
the opening for seal to go in is 1/2" (outer diameter of seal). Or very close to these dimensions. Thanks again everyone. Ron
11-07-2021, 12:29 PM | #9 |
I believe this may be what you're looking for:
https://torqueking.com/product/30065...ransfer-cases/ |
11-07-2021, 06:24 PM | #10 |
The OD for the above part is .624 or 5/8
The ID is .375 or 3/8. Some take the .578 OD. seal. Which is the seal I have a bunch of. I'll send you a couple on Monday. No charge. The link has the seal for #13.99, an insane price. Then add $11 dollars shipping cost to that. PM your mailing address. If they are not correct you need the other size. Last edited by Accelo; 11-07-2021 at 06:37 PM. |
11-08-2021, 11:54 AM | #11 |
I might be off a bit on measurement. So they might work.
Thanks Ron
11-16-2021, 09:06 PM | #12 |
Accelo got the seal today. It was bigger but I got it in ok and put oil in the top side to see if would leak by. Seems to be working good.
Thank You I owe you one. Ron
11-17-2021, 08:17 AM | #13 |
Pic. Here is the seal you need.
11-17-2021, 08:21 AM | #14 |
11-17-2021, 09:29 AM | #15 |
Thanks Jcfcamaro appreciate all the help.
Ron
