11-10-2021, 03:03 PM | #1 |
Garage Sale - Big Variety - Some GMC Specific Parts
I have decided to sell off parts I’ve been hoarding for years now and just keep the ones I need. I need the space in my garage more than I need these parts!
Buyer pays shipping and fees. I will combine shipping costs if you buy more than one item. I have already taken pictures of most of this stuff, but a few things might have slipped through the cracks. It’s going to take a long time to upload pictures of all this stuff. I’ll work on shipping quotes the best that I can, but I also have a full-time job and a family to take care of, so please be patient. Follow board rules (respond in the thread). I’m open to reasonable offers on this stuff. I’ll keep this initial post updated with sold and pending updates to prevent confusion. Engine Bay Stuff 2. Aftermarket p/s bracket - Small Block Chevy Black Steel Power Steering Bracket Saginaw Pumps SBC 350 327 | eBay - $10 + shipping 3. 68 327 intake, oil fill tube carburetor, coil, and distributor (2 bbl), all were working when I pulled them off, I’ll include a new set of spark plug wires I purchased before I went to an HEI - $20 + shipping (shipping might be high with the cast iron intake) 5. Summit racing spread bore intake – I got it free from a friend, so you can have it for the cost of shipping 6. Carburetor adaptor, works both ways (spread to square bore or square to spread bore) - $10 + shipping 7. GM HEI Distributor, probably needs a rebuild - $40 + shipping 8. Small (6”) diameter harmonic damper – $5 + shipping 10. Original fan blade from my 68 327 setup - $10 + shipping 11. Manual steering box from my 1968 truck before I went to P/S. It needs a rebuild before being put back into service - $10 + shipping 12. Clam shell mounts – free if you pay shipping 13. Later model P/S pump with brackets. The pulley spins and looks like it works - $10 + shipping 14. Various pulleys – if you see one you want or need, call it out and make an offer 16. Spark plug wire brackets with new rubber wire holders painted chevy orange - $20 + shipping 18. Core support repair section bought from forum member atog - $35 + shipping 19. Power steering line clamp - $15 + shipping Interior Stuff 23. Passenger side fresh air door, pulled from a 70 C10 in a local junkyard that hit a deer - $10 + shipping 26. 67-70 accelerator assembly. I pulled this out of my 1968 when I went to the throttle cable set up. Will come with the OEM pedal that still fits tight on the ball studs – $10 + shipping 27. Visors – Aqua/medium green, most have some tears or creases - $20 each + shipping or $50 for all of them + shipping 28. Visor clips, some aqua some light blue? Will probably clean up, but I’m not sure - $5 each + shipping or $20 for all of them + shipping 29. 67-68 parking brake cover - $35 + shipping 35. Passenger side vent window knob with washer and pin - $10 + shipping 36. Fuel gauge wire, no cracks, pretty good shape - $15 + shipping 37. Two rear view mirrors. Typical shape for original mirrors, look at pics closely - $15 each + shipping 38. Rear view mirror bracket. I think this is the later style bracket - $15 + shipping 39. Replacement lens for gauge cluster in great shape - $30 + shipping 40. Choke cable with standard knob, measures ~30” - $40 + shipping 42. Windshield wiper button escutcheon - $5 + shipping 43. Horn clock spring in great shape - $20 + shipping 44. Choke cable in original box measures ~72” no knob - $25 + shipping 49. 13/16” lug wrench - $20 + shipping 51. Tri Plus inner/outer rocker panel for driver side - $25 + shipping 51a. 67-68 Gauge cluster face - no cracks on any holes and in useable shape - $20 + shipping Exterior Stuff 33. Tri-co wiper arms - $25 + shipping 54. 3/4-ton upper control arm rod. I painted one cap and lost it, so I ordered a second rod. Then when I was moving, I found the other cap. Only test fitted, never installed/torqued. - $10 + shipping 55. Spare tire carrier, has the threaded rod. $40 + shipping 56. Pair of original door handles pulled from a 1970 - $45 + shipping 57. GMC C2500 V-Eight fender emblems, studs intact and I’ll include four speed nuts for them - $45 + shipping 58. Driver door handle that needs a repair - $10 + shipping 59. Tail light lenses, no cracks - $30 + shipping 61. GMC park light housings (turn signal housings), driver quality, great shape, but one has a small crack (pictured) - $35 + shipping Big Stuff - No Shipping 62. Primed front bumper never installed 67-70 and aftermarket - $150 63. Chrome front bumper, really clean 67-70 and OEM - $150 69. Tinted rear window with stainless trim - $100 SOLD STUFF 1. Spark plug wire brackets and heat shield from my 68 327 - $10 + shipping SOLD 4. Edelbrock 4 bbl carburetor 1407 (750 cfm). Was working when I pulled it off the motor and put it away in a box for a couple years - $100 + shipping SOLD 9. I think this is a 6 cyl. Fan guard? I got it in a box of parts - $10 + shipping SOLD 15. Throttle cable and bracket for a V8 setup - $25 + shipping SOLD 17. Engine lift brackets off a later model Chevy, easy way to pull a motor! - $20 + shipping SOLD 20. Hood hinges, they feel tight, but keep in mind they’re 50+ years old - $30 + shipping SOLD 21. Heater box with heater core in need of repair. The box has a small hole that someone covered with electrical tape. The blower still worked when I pulled it out - $15 + shipping SOLD 22. Turn signal lever, pretty clean, chrome in good condition - $15 + shipping SOLD 24. E-brake pedal, has the spring that’s always missing! – $25 + shipping SOLD 25. Pedal trim, has a small wear hole, but would be great for a driver - $5 + shipping SOLD 30. Door sill plates, I don’t see a part number so they may be aftermarket - $30 + shipping SOLD 31. Radio repair section - $40 + shipping SOLD 32. Radio delete plate with the ever evasive clips - $40 + shipping SOLD 34. Nice chrome GMC horn cap with good rubber and all parts shown - $50 + shipping SOLD 41. Window crank handles in great shape - $35 + shipping SOLD 45. True truck AM/FM radio with all brackets, harness, speaker. Untested, a good candidate for restoration (wow, I forgot how nice this was until I got it out to take pics). The FM tab is floating around and the AM tab is missing, but it might be inside the unit. - $450 + shipping SOLD 46. AM Radio with all brackets, harness, and speaker. Untested - $75 + shipping SOLD 47. 1968 Chevy glovebox door. Hinge functions and doesn't bind and the button is unlocked, but I don't have the key. $10 + shipping. Free for the cost of shipping if you have the truck it goes to. SOLD 48. Three-gauge cluster appears to be in good shape. There are no cracks around the screw holes and you can still see the outline of the choke delete, which I never had. The printed circuit has two little spots that I have photos of that might be problematic, but I don't know if continuity has been broken. $10 + shipping SOLD 50. Jack storage hardware (2 sets) - $25 each + shipping SOLD 52. R and L gravel shields, appear to be aftermarket - $20 + shipping SOLD 53. GMC headlight bezels. One ding on each bezel as shown in pics - $45 + shipping SOLD 60. Bulls eye reverse light lenses no cracks - $30 + shipping SOLD 64. Chrome front bumper with holes for lights - $150 SOLD 65. Passenger door - $250 SOLD 66. Aftermarket fleetside tailgate (no logo) - $175 SOLD 67. Stepside GMC tailgate - $100 + shipping SOLD 68. D/S fender well - $25 SOLD Last edited by Willys_MB; 03-09-2022 at 04:49 PM. |
11-10-2021, 03:12 PM | #2 |
Re: Garage Sale - Big Variety - Some GMC Specific Parts
Engine Bay Stuff
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 11-10-2021 at 03:42 PM. |
11-10-2021, 03:15 PM | #3 |
2. Aftermarket p/s bracket (first pic)
3. 68 327 intake, oil fill tube carburetor (2 bbl), coil, and distributor, all were working when I pulled them off, I’ll include a new set of spark plug wires I purchased before I went to an HEI
1968 GMC C2500 Long Bed Fleetside |
11-10-2021, 03:18 PM | #4 |
3. 68 327 intake, oil fill tube, carburetor (2 bbl), coil, and distributor, all were working when I pulled them off, I’ll include a new set of spark plug wires I purchased before I went to an HEI - continued
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 11-10-2021 at 05:05 PM. |
11-10-2021, 03:19 PM | #5 |
11-10-2021, 03:20 PM | #6 |
4. Edelbrock 4 bbl carburetor 1407 (750 cfm). Was working when I pulled it off the motor and put it away in a box for a couple years - continued
11-10-2021, 03:22 PM | #7 |
11-10-2021, 03:24 PM | #8 |
11-10-2021, 03:27 PM | #9 |
10. Original fan blade from my 68 327 setup 11. Manual steering box from my 1968 truck before I went to P/S. It needs a rebuild before being put back into service 12. Clam shell mounts
11-10-2021, 03:30 PM | #10 |
11-10-2021, 03:31 PM | #11 |
14. Various pulleys – if you see one you want or need, call it out and make an offer - continued
11-10-2021, 03:35 PM | #12 |
16. Spark plug wire brackets with new rubber wire holders painted chevy orange 17. Engine lift brackets off a later model Chevy, easy way to pull a motor! 18. Core support repair section bought from forum member atog - see his post here
11-10-2021, 03:37 PM | #13 |
20. Hood hinges, they feel tight, but keep in mind they’re 50+ years old 21. Heater box with heater core in need of repair. The box has a small hole that someone covered with electrical tape. The blower still worked when I pulled it out
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 11-10-2021 at 05:07 PM. |
11-10-2021, 03:42 PM | #14 |
Interior Stuff
22. Turn signal lever, pretty clean, chrome in good condition 23. Passenger side fresh air door, pulled from a 70 C10 in a local junkyard that hit a deer 24. E-brake pedal, has the spring that’s always missing! 25. Pedal trim, has a small wear hole, but would be great for a driver 26. 67-70 accelerator assembly. I pulled this out of my 1968 when I went to the throttle cable set up. Will come with the OEM pedal that still fits tight on the ball studs
11-10-2021, 03:45 PM | #15 |
pics of the gmc tailgate please, interested
can i see a pic of the gmc headlamp bezels as well? wanbt to see what year they are
1967custom Last edited by michael bustamante; 11-10-2021 at 05:42 PM. |
11-10-2021, 03:49 PM | #16 |
11-10-2021, 03:51 PM | #17 |
11-10-2021, 03:54 PM | #18 |
11-10-2021, 03:56 PM | #19 |
11-10-2021, 03:58 PM | #20 | |
11-10-2021, 04:01 PM | #21 |
11-10-2021, 04:03 PM | #22 |
11-10-2021, 04:06 PM | #23 |
42. Windshield wiper button escutcheon 43. Horn clock spring in great shape
11-10-2021, 04:08 PM | #24 |
43. Horn clock spring in great shape - continued
44. Choke cable in original box measures 72” no knob
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 11-12-2021 at 02:26 PM. |
11-10-2021, 04:11 PM | #25 |
48. Three-gauge cluster appears to be in good shape. There are no cracks around the screw holes and you can still see the outline of the choke delete, which I never had. The printed circuit has two little spots that I have photos of that might be problematic, but I don't know if continuity has been broken. 49. 13/16” lug wrench 50. Jack storage hardware (2 sets) 51. Tri Plus inner/outer rocker panel for driver side 51a. Gauge cluster face [IMG] [/IMG]
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 11-10-2021 at 05:03 PM. |
