11-25-2021, 12:14 PM | #1 |
Manual clutch linkage
Trying to figure out how to do my clutch
easier to press without always get cramps in the calf’s 🥵 Anyone have some solution? I have a 69 with three on the three floor shifter. |
11-25-2021, 02:12 PM | #2 |
All about them K’s
Re: Manual clutch linkage
I have a hydraulic setup on my 72. The pedal is very easy to push.
I used this master cylinder/linkage setup http://67-72chevytrucks.com/vboard/s...d.php?t=652871 For the clutch side I used an 85+ square body hydraulic clutch aluminum bell housing, slave cylinder and clutch fork with a 12” LUK clutch kit for a ‘72 K20. My truck is a 4 speed, but this setup would work for the three speed as well I would think. Posts 135 and 136 here show some of the parts I used. http://67-72chevytrucks.com/vboard/s...=662879&page=6 Posts 159-162 here show some pictures of it installed as I was plumbing everything out as well as a parts list. http://67-72chevytrucks.com/vboard/s...=662879&page=7 Here are a few pictures of the master cylinder/linkage installation on the cab. If you are interested in this setup, I’ve got several hydraulic clutch aluminum bell housings. I would be willing to give you one for free if you pay the shipping. I’m sure that’s not an easy to find part in Sweden. I could probably help round up a few of the smaller things like the fittings and lines and ship them all together if that wild help.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 11-25-2021 at 02:18 PM. |
11-25-2021, 02:39 PM | #3 |
Changing the pressure plate to a diaphragm type instead of the 3 finger will help a lot
11-25-2021, 02:46 PM | #4 |
That's what we call an anti-theft device...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-25-2021, 02:56 PM | #5 | |
Yes, it’s hard to get this parts and also it’s not many car guys that’s know how to solve this problems. So I will gladly pay for shipping cost. I’m sure that some of the parts I might find here, but in that case I need to know what parts I need. Thanks a lot 👍 |
11-25-2021, 03:24 PM | #6 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-25-2021, 03:26 PM | #7 |
11-25-2021, 04:59 PM | #8 |
Kwmech posted what may possible be lest expensive solution. Of course it requires pulling the transmission to replace the clutch pressure plate.
The diaphragm style gets easier to hold down to the floor where as the finger type gets harder the further you push. Both converting to hydraulic and/or changing require some mechanical knowledge. After having all three style clutches (diaphragm, finger and hydraulic) I would take the easy route and replace the pressure plate with a stock style. Hydraulic give more mechanical advantage but if it tough to hold to the floor it will still be with a hydraulic clutch. I am assuming your motor is a six or small V8 with a three speed. The stock pressure plate should last a long time. Just don't get a rebuilt one, purchase new and drive on. My daughter can drive, a stock clutch, in traffic without issues. I do recommend confirming the clutch style by a visual inspection before proceding. Best of luck. |
11-26-2021, 12:01 AM | #9 |
All about them K’s
I agree totally on the clutch style being one area that can cause a stiff pedal, however my mechanical linkage was beyond worn out and binding up.
