11-28-2021, 10:02 AM | #1 |
QA1 control arms vs modified stick parts
QA1 offers more caster, and sounds like a great upgrade. Pricey. Well yes.
Rebuild the stock stuff about $600 with labor to press the bushing in, and installing myself. To which I could pancake the crossmember, and move the lower A arms forward. To gain caster. Has anyone used QA1 arms after having a nicely set up stock suspension. We're you impressed or just $1500 lighter? |
11-28-2021, 02:18 PM | #2 |
Re: QA1 control arms vs modified stick parts
I have the qa1 setup w/ coilovers. Night and day. Would buy them again.
Not cheap, but the ride quality is worth it.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
11-28-2021, 05:32 PM | #3 |
I used the same setup on my 77. Like pcmcobra said money well spent.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
11-28-2021, 06:38 PM | #4 |
Do the QA1 arms center the A arms?
11-29-2021, 02:22 PM | #5 |
Are they better than the stock units?
Tubular arms are generally structurally more sound/rigid vs. stamped OE arms so that's better. If they come loaded w/the bushings & BJ's already installed & you were already needing to spend $$ for rebuilding the OE arms, that negates some of the 'new purchase' investment expense. They're coated? That adds to the investment amount as well.
11-29-2021, 07:30 PM | #6 | |
Even generic arms are stronger then stamped. Except the ball joints, and don't move items around for more camber. So I can play with them. QA1 is a great name, and have used many of there other items with great happiness. Just I have always been told, and have read. A arms alone don't make a big difference unless pick up points are moved. |
