11-30-2021, 11:02 AM | #1 |
Rear seat floor mount leveling shims
Pretty sure these aren't re-popped, but wondered if someone had ever made up a batch and had some left over. Or had luck removing a good set. The ones I've seen or tried to remove almost disintegrate. Thanks, Jon.
11-30-2021, 11:42 AM | #2 |
Carpe manana
Re: Rear seat floor mount leveling shims
Can you post a photo of what you're describing? I'm drawing a blank as to what these shims are. I've just seen the rear seat bolted to the floor without shims.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-30-2021, 11:54 AM | #3 |
Like these four in the picture. They allow the back legs on the rear seat to sit level across the ridges in the bed.
11-30-2021, 01:09 PM | #4 |
Carpe manana
Gotcha. I've not seen those reproduced FWIW.
12-01-2021, 01:51 AM | #5 |
Have these they’ve been media blasted. One on far left has a minor rust through
May need to go through the for sale section not sure. Thanks much , Thomas
Some progress is better then no progress |
12-08-2021, 04:32 PM | #6 |
How many do you need? All of them?
12-08-2021, 10:16 PM | #7 |
12-08-2021, 10:18 PM | #8 | |
12-09-2021, 10:18 AM | #9 |
Those can easily be reproduced anywhere.
If anyone is interested, I can make a DXF file that you could use at your local fab shop with a plasma/laser table. I will need dimensions. |
