Old 12-04-2021, 10:45 PM   #1
custom10nut
custom10nut's Avatar
Radiator overflow tank cap
My truck: 70 C-10
Is there a vendor that sells a replacement cap for my Radiator Overflow tank?
The original was Blue.
It kinda disintegrated lasts summer
I’ve looked in every catalog I have, and even on vendor sites, but have not been able to find one.
custom10nut is offline   Reply With Quote
Old 12-05-2021, 12:39 AM   #2
68 P.O.S.
Re: Radiator overflow tank cap
Pics, or knowing what unit you have, would help
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-05-2021, 09:43 PM   #3
custom10nut
I can get a pic tomorrow, but I can tell you the cap was a “lighter Blue”, with the tank being a semi opaque white, and the tank was mounted to the passenger side fender well. I’ve since moved it under the battery to “clean up” the engine bay
Old 12-06-2021, 01:28 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
As far as I know, these trucks didn't come with a radiator overflow tank. Unless it was an option, or you have an aftermarket tank. I've owned many 67-72's and none of them had a factory overflow tank.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-06-2021, 01:55 PM   #5
72afr
Beep! Beep!
72afr's Avatar
Gary
That's not entirely true. My truck has one and is noted on the SPID as 18B6AA Radiator Overflow Tank. From an older thread I found, it was determined this was somewhat common on government trucks, which mine was.
Edit: sorry, I missed the "option" portion of your comment. Got too excited about one of the only options my truck had being a rare one.
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport
2003 Chevrolet 2500HD CC 6.0 4wd
2004 Jeep Rubicon some aftermarket stuff...
2019 Jeep Unlimited Rubicon (the wife's baby hauler)
72afr is offline   Reply With Quote
Old 12-07-2021, 04:46 PM   #6
GASoline71
GASoline71's Avatar
Originally Posted by 72afr View Post
That's not entirely true. My truck has one and is noted on the SPID as 18B6AA Radiator Overflow Tank. From an older thread I found, it was determined this was someone common on government trucks, which mine was.
No sweat bud! I figured there was probably some sort of option for an overflow tank. But when I bought my first 1967 C10 it didn't have one and it was the first vehicle I'd ever owned without one.
Gary
Old 12-08-2021, 04:57 PM   #7
custom10nut
Here’s a pic of the top of my overflow tank.
The opening is 2 1/4 inches across, and used to have a light blue blue cap.
It could be that the tank was added some time before I got the truck
Old 12-08-2021, 05:54 PM   #8
72afr
Beep! Beep!
72afr's Avatar
Hard to tell from the picture. Could be the optional rad overflow tank or someone put in another washer fluid tank for an overflow with a different cap. Mine has the tank on the driver side radiator with a hose run to the passenger side of the rad. This option had a specific radiator cap as well. The overflow tank has an opaque cap that matches the tank.
