12-05-2021, 10:28 AM | #1 |
New Member
Mac in North Carolina
I have a 1964 3/4 ton longbed stepside made in Atlanta that my father bought in 1972. It was originally a small six, manual shift and either 4.56 or 4.88 rear end gears. Basic model.
It is now being “fixed up” not restored, because the use of that word increases parts and labor prices. It now has PS, PB, factory air, disk brakes on the front. By this time next year it’s will have a 1965 Corvette engine, probably around 325 HP, and it will be painted inside and out with Rhino liner in the bed tinted to match the truck color. I am looking for 5 17.5 eight lug rims to fit this truck. I am also looking for a source to find out if the 17.5 rims used in the fifties will fit a sixties truck, and the parts number for both, if they are different. I have learned a lot on this forum, y’all are a smart and well informed bunch. |
12-05-2021, 12:46 PM | #2 |
Re: Mac in North Carolina
Welcome
You all ready know the wealth of info on here. If you keep your eyes out in the Parts section, Maybe there will be some rims you could use. Here's the link: https://67-72chevytrucks.com/vboard/...isplay.php?f=7 FYI: Subscribed members can post a want to buy add. I know you have probably seen the great deals that can be had. Again
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
12-05-2021, 10:56 PM | #3 |
Welcome! We would love to see some pictures, and if you're up for it, start up a build thread in the 60-66 projects and builds section.
As Getter-Done said, you must be a Premium member to post a Want to Buy, What's it Worth, or For Sale thread
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-05-2021, 11:15 PM | #4 |
Well you have been here for a couple of years.
You can search the Events section also The swap meets are opening back up. Most members post the current swap meets. You may find some thru the info of the swap meets in your area.
