12-06-2021, 07:43 PM | #1 |
Power Steering Frame-Reinforcement Plate
Does anyone know the history of the power steering frame reinforcement plate on 67-72 trucks? I've been thinking about some questions:
-What models had it? No 2wd trucks? Just some 4x4's? Shortbeds and Blazers only? -Was there a firm date that GM began production on those models going forward? Are there examples from every production plant? I have a 72 K20 that does not have the plate (built in Flint, May 1972). I also have a K10 shortbed that does have it (built in Fremont, January 1972). I'm surprised the K20 doesn't have it, especially given its later production date. I did some thread searching and didn't find much definitive info. Let me know if something already exists. EDIT: Perhaps we can develop a pattern based on our responses. Here is a summary of the replies: (year & model, Build Plant, Build Month, member name) Have Brace 1970 K10 SWB___ --_______--_______________Love 70 Chevys 1972 K5________St. Louis __--______________tim71 1972 K10 SWB___--________--______________Richard 1972 K10 SWB___Fremont___10/20/71____Custom/10 1972 K10 SWB___Fremont___1/72__________402Bowtie No Brace 1971 K1500 SWB__Fremont__--____tim71 1972 K20________Flint_____5/72__402Bowtie 1972 K20________Janesville_6/72__57taskforce Last edited by 402Bowtie; 12-10-2021 at 06:02 PM. |
12-06-2021, 08:44 PM | #2 |
All about them K’s
Re: Power Steering Frame-Reinforcement Plate
I’ve always thought this one was funny. My early June 72 Janesville K20 does not have the plate. I wish it did. My frame probably wouldn’t have cracked. I’ve got the ORD repair plate and cross brace now though. My 69 short K10 doesn’t have the plate either. But then again the whole crossmember was missing when I got it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-06-2021, 09:45 PM | #3 |
The only vehicle I've seen them on were the K5s. I bought one on this forum years ago and put it on one of my K30 conversion trucks
12-06-2021, 10:08 PM | #4 |
My Fremont built 71 K1500 SWB does not have plate, but my 72 St Louis built K5 does have the plate.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
12-06-2021, 10:37 PM | #5 |
Interesting - keep the replies coming! So far, it seems like it might have been a 72 model year thing for k5 and k10 trucks only.
12-06-2021, 11:38 PM | #6 |
All about them K’s
Makes perfect sense actually because the K5 and short K10 use basically the same frame (obviously wheel base and cab mount quantity and spacing are different) but the frames are the same thickness. The long K10 and K20 use the same identical beefier frame, only axles and springs are different. I bet with the thinner frame gauge of the K5 and short K10 it necessitated the brace. (all the K trucks should have had it in my opinion)
12-07-2021, 01:07 AM | #7 |
It might be beneficial to find out what the frame vender was when you find a power steering frame reinforcer.
12-07-2021, 04:43 AM | #8 |
My current SWB 72 K10 has the factory frame reinforcement. I recall my last 72, a LWB K20 having it as well. Could be mistaken, many years ago. Current truck has two holes in it for a bracket at the front crossmember. Maybe only a bracket there on the K20. The holes almost line up with the separate reinforcement included with the ORD steering brace. If there is is a difference on some K trucks it is curious ORD only offers one brace for 67-72 trucks. Their brace allows for the factory plate. On rear most steering box bolts the upper steering box bolt does not go through factory reinforcement plate but the lower does.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 12-07-2021 at 04:51 AM. |
12-07-2021, 09:12 AM | #9 |
6>8 Plugless........
I removed one from a K5 and installed it on my Longhorn when I 4x4 swapped it. I'll have to check my K20s to see if they have them. I'm guessing not.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-08-2021, 06:36 PM | #10 |
My 72 k10 swb 4x4 has it.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
12-10-2021, 01:09 PM | #11 |
My 1970 short box K10 has the bracket due to its one and only luxury......power steering! (Besides its dealer installed AM radio.)
12-10-2021, 01:20 PM | #12 |
Thanks for sharing. Do you know which plant your truck was built (represented with 6th digit in VIN)?
12-10-2021, 01:34 PM | #13 |
I saw yours on your build thread, which got me thinking about this question. Do you mind sharing your truck's build month and assembly plant?
12-10-2021, 02:50 PM | #14 |
My truck was built in the Fremont plant, don't know the build date.
12-10-2021, 04:43 PM | #15 |
All about them K’s
Pm me with your vin or post it here and I’ll get you a rough date.
12-10-2021, 05:19 PM | #16 |
I'll pm you in a little bit.
12-10-2021, 05:51 PM | #17 |
From 57taskforce's calculations my truck has an approximate build date of 10/20/1971
Gary
12-12-2021, 10:31 AM | #18 |
One of the First
Ive seen add in by owners that is usually bolted on the frame. If you have the frame rivets, top/bottom, that could define it as a factory install. Not to many people will go to the extent to rivet to frame.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
12-12-2021, 06:15 PM | #19 |
Answer to 402 Bowtie: My truck is a 1970 model built in September of 69 at the Tarrytown NY plant.
