Old 12-08-2021, 07:29 AM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
1972 Chevy Suburban C10 Cummins Swap
This is going to be the build thread for my wife's 1972 C10 suburban. Leon (LockDoc) found this for us last year (2020) and we were able to get it purchased. It is rusty but luckily it's not completely hashed. The original 402 was locked up and I have already removed the 402/TH400. It is getting a spark plug delete, marker light delete, trim delete, bumper delete, and 72 front clip delete. My wife wants this to not look like a truck, in her words. I have a hard time with that because, well, it is a truck and I really like the 72 grill.
The kids have already been helping on this unit. They got the task of starting the clean out. The boys have been on degrease duty too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-08-2021, 07:34 AM   #2
Dieselwrencher
Re: 1972 Chevy Suburban C10 Cummins Swap
The front clip is off and the new to it powerplant installation has begun. I had to remove the 72 only BBC RH heat shield to allow the bell housing to get down far enough. I was surprised how much of the floors were still solid.
Ryan
Old 12-08-2021, 07:38 AM   #3
Dieselwrencher
Here the engine is getting close to where I'd like it to be. The factory brake booster setup has to go though. This will be getting hydraboost now. The injection pump is hitting the booster and I still need to go back about another inch so the factory vacuum booster is out.
There is a portion of the patch panel collection we have gotten so far. How crazy is it right now? Stuff I never thought would be out of stock and on back order is crazy!
Ryan
Old 12-08-2021, 07:47 AM   #4
Dieselwrencher
This was done last spring. I forgot to post a thread in here on it.
I've gotten the engine and trans bolted in. I just have to drill new holes for the trans cross member and I will have to move the hoses going back to the rear hvac. These hoses will be replaced anyway.
I'm waiting on parts to be able to mount the turbos. Until then I need to get the 67 front clip on and start modifying the core support because I'm going to use a 2nd gen dodge radiator and intercooler. I'm also going with hydra boost. I need to decide if I will make an adapter bracket or source one.
Ryan
Old 12-08-2021, 07:57 AM   #5
Dieselwrencher
I've got to remove the stock BBC exhaust hangers. More than likely I'll run 4" exhaust to possibly dual 3" tail pipes behind the back tires. I'm planning on cutting the control arm mount cross member and putting a piece of 5" tube in there to give a place for the 4" to pass through.
I will take the drive shaft to the drive line shop next week. Get the front shaft shortened, have spicer non greaseable u joints installed and a new carrier bearing.
The trans has a double deep pan for extra fluid capacity and it doesn't hang too far down luckily. This burb will more than likely only get a 3" drop and that will be it. It needs to be driven on bad roads and weird approach angles.
Ryan
Old 12-08-2021, 08:01 AM   #6
Dieselwrencher
This year has been full of a lot of surprises which have taken my time away from this project. We were hoping to get it done this year but it will be pushed back to spring. Parts shortages along with money shortages don't help.
Since this is Momma's rig, we couldn't leave it stock. It is getting a second spinning muffler. I also wanted to use the Dodge intercooler and radiator in this one. I chopped up the rusty 67/68 radiator support and grafted in the 2nd gen dodge one. I wanted the extra cooling capacity and it makes it a lot easier if you can go to any parts store and gets parts if we ever need to especially on a road trip.
Ryan
Old 12-08-2021, 08:08 AM   #7
Dieselwrencher
The green hood is just a mock up hood. I have since gotten a nicer one from Leon. I'm sure glad he has a lot of parts for these trucks. It's going to be a bad deal when he's out of them.
The radiator hoses went right on without any mods. The Cold side intercooler pipe worked as well. I'll have to modify the hot side since the addition of the second muffler. I have ordered a reman steering box with the flare/o ring type fittings so I can run the dodge pressure hose. One more part that usually would need modified.
I need to figure out the hydra boost next. I also have to decide if I want a shift cable for the transmission or a linkage. I have a tilt column I need to get put in this so I can work on that.
My son Colt was helping clean the interior out. Someday it will be chop cut rebuild time for the body. That's probably the last stuff I've done to it for a while. I've been swamped with helping my Dad on hos place, work, and other work.
Ryan
Old 12-08-2021, 01:41 PM   #8
diesel burner
diesel burner's Avatar
Looks good Ryan, I'm along for the ride.... I'm surprised that your slant hood cleared the radiator cap.... your radiator must be mounted lower than mine.
I'm curious about what you plan to do for inner fenders.... I didn't use the stock dodge lower hose because of inner fender clearance. I used a cold side aftercooler hose on the hot side because the sharper angle required less inner fender trimming. I still need to build patches for the holes I cut to clear aftercooler
71 C10 Cheyenne 396, turbo 400
71 C20 Custom Camper 383,tko 600,14 bolt project
71 K20 Custom,Cummins,NV4500,NP205,dana 60F,dana 80R
06 GMC sierra 2500 extended cab duramax,allison
05 Toyota Corolla (commuter)
18 Chevy Tahoe RST (wifes car)
08 HD Roadglide
diesel burner is offline   Reply With Quote
Old 12-08-2021, 01:53 PM   #9
Dieselwrencher
I'm surprised the radiator cap clears too. It sure didn't look like it was going to before I put the hood on and shut it. I plan to use stock inner fenders just modify them. I had to modify them on my orange truck because of the piping too. I hope to keep the piping back farther so a guy can access the oil filter without a fight. I have to remove the air inlet pipe from my excursion to get to the oil filter and then you have to pull the filter down behind the engine cross member to get it out thanks to the ac line and cac piping. On my orange truck I can spin the oil filter off from the bottom with my blue point 3 jaw filter tool and a long extension. It is just a pita to do. I do have some oil filter relocator set ups Ryanroo made up that I probably should use but ya know.
Ryan
Old 12-12-2021, 11:06 AM   #10
gmikkels
Another Awesome build from Ryan!!!
gmikkels is offline   Reply With Quote
Old 12-12-2021, 11:32 AM   #11
gmikkels
Ryan,
On my hood latch,I removed the coil spring, and used a brake return spring to pull the latch forward, this gave me about a 1/2 inch of much needed clearance.
Gene
Old 12-12-2021, 04:05 PM   #12
Dieselwrencher
Originally Posted by gmikkels View Post
Ryan,
Gene
Nice and great idea. Where's your build thread?
Ryan
Old 12-12-2021, 04:40 PM   #13
gmikkels
Five inch square tubing will work great for your crossmember
Old 12-27-2021, 08:05 PM   #14
dwntwn
dwntwn's Avatar
Awesome! Looking forward to seeing how this come out, and I'm stoked to see a new build on here. (I've been slowly working on one, will start a thread too)
1966 c10, short fleet, 402ci 700r4
1988 r20 Suburban 454ci tbi, th400 (12v Cummins soon)
1980 shovelhead, hardtail, open primary
1998 FXDWG
dwntwn is offline   Reply With Quote
Old 03-25-2022, 01:29 PM   #15
gmikkels
Hello Ryan,
How is the Sub coming along?
Gene
Old 03-25-2022, 02:02 PM   #16
Dieselwrencher
Hello Ryan,
Gene
Unfortunately no real progress lately. I've been collecting parts for it but had no room in the garage and some things had to go to storage.
Ryan
