12-18-2021, 10:43 AM | #1 |
Transfer case question
I purchased a case on ebay to replace my cracked one. Everything seems the same except there are no mounting holes for mounting bolts..what am I missing here ?
12-18-2021, 06:22 PM | #2 | |
Re: Transfer case question
That's not really a "mounting point". A support brace goes from there, up the side of the engine block and across the starter. Most of them get removed during the first starter replacement and never reinstalled.
That's not right? I'm thinking about the ones from the cover over the flex-plate/torque convertor, going across the starter.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. Last edited by LONGHAIR; 12-18-2021 at 06:30 PM. |
12-18-2021, 07:54 PM | #3 |
All about them K’s
Those holes have a bracket that bolts to them and the frame with bushings. That bracket can be a heated topic amongst 205 lovers. Some associate the bracket to causing cracked transmission/transfer case adaptors and pitch them asap. Others swear they would never run without them because it’ll crack the adaptor… I’ve run them and not run them and never broke an adaptor… go figure. Point being those holes aren’t necessary if you don’t mind not running the bracket.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-18-2021, 08:16 PM | #4 |
12-18-2021, 08:24 PM | #5 | |
12-18-2021, 08:26 PM | #6 |
Yes alot of people say do not put the bracket on
12-18-2021, 08:27 PM | #7 |
12-18-2021, 11:29 PM | #8 |
All about them K’s
My current K20 does not run the mount, its still plenty stout.
12-21-2021, 04:00 AM | #9 |
Currently Blazerless
If you do end up using the side support I suggest you use the OEM rubber bushings and not the aftermarket poly bushings.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
12-21-2021, 12:26 PM | #10 |
What did you pay for the case ? Small or large input bearing ?
I got a bunch of parts and cases to clean out . As said brace rod holes or older got frame brace but they tend to brake adapter or tail on trans . If you need them just drill & tap them .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-21-2021, 12:31 PM | #11 |
K5Camper
Not worth going through the effort to drill the holes out for the side mount. People can debate it but there's a reason GM stopped using the mount.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
12-21-2021, 12:32 PM | #12 |
12-21-2021, 12:39 PM | #13 |
K5Camper
Again, for the effort it would take to drill out the housing I don't think it's worth it. A large amount of squarebody trucks never got that strut rod.
12-21-2021, 12:41 PM | #14 |
I always put the support rod back. GM continued the use of the bell housing rod up through 91 on the Blazers and Suburbans with the 208 and 241 t-cases. When I converted my suburban to a 4l80e I had to lengthen the rod for the longer transmission. It was the 205 ?square mount? that got the bad rap with breaking the adapter or the trans case, not the bell housing rod
12-21-2021, 03:55 PM | #15 | |
12-21-2021, 09:45 PM | #16 |
12-22-2021, 12:17 AM | #17 |
All about them K’s
Hell yea man that looks awesome.
I agree completely.
12-22-2021, 09:11 PM | #18 |
looking good there . .
