Old 12-21-2021, 08:03 PM   #1
Peanut74
Got Snowballs dash done!!!
Well today is a milestone day as I got the dash completed!!!.
I did remove the cigarette lighter and put in a USB port. But I did use the lighter knob to put on the front of the USB cover to keep with the OEM look.
Next up, after finding the backup light short, will the steering then brakes. Or, maybe finish up the stereo box where the gas tank use to be.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 12-21-2021, 10:31 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Got Snowballs dash done!!!
The column looks like it is angled to the left, is it just the pic?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-21-2021, 11:35 PM   #3
kev2809
low n' slo
kev2809's Avatar
that cig lighter thing is nice! how did ya do it with the stock know to hide it?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-22-2021, 10:48 AM   #4
Peanut74
The USB port is for a boat so it has a rubber cove for it. You can see the cover in the detail picture. What I did was drill a hole in the cover and ground down a screw to act as the shaft for the knob. I ground down the head to fit in between the two teeth and a low profile. The knob is from the wiper switch so you have the set screw to hold it in place.
As for the steering column looking like it is to the left. It is as I only have it hanging there by the front bracket. Its not fastened to the firewall as I put it in to get the measurement from the steering box to the new steering column.
Old 12-22-2021, 11:05 AM   #5
70STOVEBOLT
It's looking good.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 12-22-2021, 01:25 PM   #6
FRCvette
Looks great. I like the cig lighter switch out.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 12-22-2021, 01:43 PM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
Very nice. Digging the color too!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-23-2021, 08:00 AM   #8
Peanut74
Thanks guys, it has definitely been a long road and frustrating at times but it is nice to see it getting closer to the end and being able to drive it.
Old 12-23-2021, 02:48 PM   #9
68Gold/white
Tell us about that radio!
68Gold/white is offline   Reply With Quote
Old 12-25-2021, 12:35 PM   #10
Peanut74
The radio and center speaker are RetroSound. Radio is a RetroSound Hermosa (RES-HB-119-23-93) with Bluetooth, etc. I bent the backside of the ashtray down so that I could run the radios external USB input and aux cable inputs there. As for the phone mic I ran that up the A-pillar and out where the sun visor mounts. Putting on the rear support strap is critical as the radio handle stems are very weak and would not support the radio for long.
For the center speaker its a RetroSound D-412. They claim it is a direct replacement but its not. It is taller so its a vey tight fit when you go to put the radio in. A/C
I'm in the process of building a speaker box where the gas tank was. That will be for the rear speakers. Current plan for the amp is to mount it under the center jump seat. The bass speaker will need to be a shallow one and be put in the speaker box also.
