12-30-2021, 10:07 PM | #1 |
Front rotors and brake calipers..whats the best?
Figured I would reach out and ask opinions of front Calipers, Rotors and pads for a K10?
Do I upgrade and use a slotted disc? Remanufactured ACDELCO Calipers? WildWood? Carbon Fiber pads? |
12-30-2021, 10:33 PM | #2 |
Re: Front rotors and brake calipers..whats the best?
I really don’t know the answer but I can tell you that the acdelco reman ones are hit and miss. Just buy local and take a look before you pay. I had to send some back to Rock Auto recently and that’s a PITA. They appeared to be almost completely rusted away and then cleaned up. One of the ears was pretty much gone. You think they would screen cores better that that…
12-31-2021, 12:33 AM | #3 |
My mechanic sourced all the brake parts locally. Although I did put the Wildwood calipers on the front. Replaced the rotors with stock rotors, no slotted ones.
Smitty '71 Short Fleetside Spring Valley, Ca. |
12-31-2021, 09:50 PM | #4 |
What year is your K10? I'm assuming 71-72. If so, It's pretty hard to beat stock calipers and Wagner semi-metallic pads, or Wagner severe duty pads. They will just about push you into the steering wheel, assuming your master cylinder, booster, and rear drums are in good shape.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 12-31-2021 at 10:01 PM. |
12-31-2021, 11:56 PM | #5 |
Rebuild the calipers yourself. They are not that hard to do. You will need a caliper cyl. hone but it is not very expensive. I like the ceramic pads. Great stopping power & they do not get the wheels dirty.
George |
01-01-2022, 03:35 PM | #6 |
Post Whore
What is the intended usage of the truck?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-01-2022, 11:01 PM | #7 |
01-02-2022, 03:55 AM | #8 |
Very happy with my Wilwood 6 piston front/4 piston rear. Crazy good stopping power and has a great feel.
01-02-2022, 04:26 AM | #9 |
I like to use off the shelf items I can get at a local parts store for maintenance parts myself. With the Ram 3500 brake upgrade on my truck, the rotors and calipers are OEM in stock pieces. Yes they are not GM but readily available. Picked up all the parts same day. Slotted and drilled rotors will fade less but provide less initial stopping power. It is a personal choice
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
