Old 01-14-2022, 02:33 PM   #1
JDon99
Anyone Running an LSA in a 63-72?
Looking for anyone who has put an LSA in a 63-72. Specifically trying to find out if the stock accessory drive fits in the frame. Thanks fellas!
JDon99 is offline   Reply With Quote
Old 01-14-2022, 03:22 PM   #2
Richard
Re: Anyone Running an LSA in a 63-72?
Installed an LSA in my 72 K10. Not running yet but you can see pics in my build thread. I never considered using the stock accessory drive because there are no provisions for a power steering pump. The low mount A/C would be close if it even fits.
Richard
Old 01-14-2022, 04:23 PM   #3
JDon99
Are the frame widths the same between the 2wd and 4wd? My LSA was out of a ZL1 so it didn't have the p/s pump but the CTS-V had hydraulic p/s. I won't be running AC in the truck.
Old 01-14-2022, 10:05 PM   #4
Richard
I think so. For sure the same at core support. Think the 4wd frame raises a bit more than 2wd over the front axle area.
Richard
Old 01-15-2022, 09:07 AM   #5
Joyridin
I don't have an LSA in mine, but the L83 I have does have a low mount A/C and it fits within the frame rails easily. I am also running a p/s pump on the lower drivers side using the GM Type II pump and there is plenty of room. I am going to run a remote reservoir though.
Joyridin is offline   Reply With Quote
Old 01-15-2022, 04:41 PM   #6
JDon99
Who's mounts are you using?
Old 01-16-2022, 09:22 AM   #7
Joyridin
I used ITC Billet. They have 4-5 adjustment front to back. I had to mount the engine 1.75" forward of where it originally mounted and trimmed the mount so the A/C compressor would fit. Everything came out nice.
https://www.ictbillet.com/sbc-to-ls-...acket-set.html
