01-21-2022, 09:17 AM | #1 |
ABS Kick panels
I need to cover the kick panels, as the driver's side still has the inside louvers for the old side vent. I had planned on covering the kick panels and looked at these early on. It is time to put some speakers in the kicks and so I'm behind again.
I am looking at the White Wolf ABS kick panels. Has anyone used them, or any other interior kick panel? I see a number that say "cardboard", but I think I want the ABS material, unless someone can tell why not. Any help is appreciated.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
01-21-2022, 09:52 AM | #2 | |
Re: ABS Kick panels
I used the ABS for my door card backers as well as my other interior panels. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-21-2022, 10:03 AM | #3 |
Re: ABS Kick panels
Thanks for the suggestion. How did you cut it? At 1/16 I'm guessing it was fairly flexible, right?
01-21-2022, 10:18 AM | #4 | |
Re: ABS Kick panels
Marc
01-21-2022, 10:19 AM | #5 |
Re: ABS Kick panels
Thanks, I just looked it up on Amazon. I think I'll try it.
01-21-2022, 10:30 AM | #6 |
Re: ABS Kick panels
One more question for now. Is the 1/16" thick enough to hold its shape? I mean for the roof for instance or the door panel?
Thanks for the help.
01-21-2022, 10:37 AM | #7 | |
Re: ABS Kick panels
For my door cards I used 3/16 foam over the ABS then wrapped with material. I think 1/16" by itself would look too thin and flimsy for door cards. Marc
01-21-2022, 08:27 PM | #8 |
Re: ABS Kick panels
Glenn 1951 3100, Area51 1955 BelAir, 4EVER17 1987 R10, Ethel Copper Hill Rod & Custom http://67-72chevytrucks.com/vboard/s...d.php?t=829856 |
01-21-2022, 09:57 PM | #9 |
Re: ABS Kick panels
Cheap enough and easy to make out of fiberglass
Check out my build thread
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
01-22-2022, 07:14 PM | #10 |
Re: ABS Kick panels
01-23-2022, 02:23 PM | #11 |
Re: ABS Kick panels
If you give me your dimensions, I probably have enough scrap material for kicker panels. You cover the shipping and its yours.
Marc
01-23-2022, 05:37 PM | #12 |
Re: ABS Kick panels
Marc,
Thank you for the offer, it is very generous. I think I'm going to try it myself. As I've said, I keep learning as I go. However, if I butcher it too bad, I'll be in touch.
01-23-2022, 05:39 PM | #13 |
Re: ABS Kick panels
Gsinon,
Thanks, but I have a set that look a lot like those. Laura took one look and said it was not what she wanted. So, I'm going to flat with smaller speakers inset.
01-24-2022, 11:19 AM | #14 | |
Re: ABS Kick panels
It's pretty easy stuff to work with, I'm sure you will be fine. Marc
