Old 01-24-2022, 07:13 PM   #1
Magicalzoomer
1984 Center Link Compatibility from other GMs
Hi Guys,
I am in the process of changing the tie rods/drag links on my 1984 blazer and am having major issues removing the tie rods from the center link adjusting sleeve on either side (been using a torch and lots of PB blaster with no luck).
Is there a center link I can use from another GM, or a universal one that will allow the tie rods to fit properly? It’s a straight bar with a tab for the steering stabilizer.
Thanks for your help!
Magicalzoomer is offline   Reply With Quote
Old 01-31-2022, 05:56 PM   #2
Magicalzoomer
Re: 1984 Center Link Compatibility from other GMs
In case anyone is wondering, SkyOffroad.com offers a bar that supports Gm hD tie rods. I ended up giving it one more shot and started to beat on the nuts with a sledgehammer and eventually got one loose and then cut the other one off with an angle grinder.
