02-07-2022, 10:40 AM | #1 |
70 k10 front problems
2 years into trouble. replaced wheel bearings twice but she keeps eating them- causing the steering to pull to the right magically- dangerous. I have an 85 from axle i picked up for 300 (disc brakes). rather than swapping the whole axle, can I just replace it from the 'knuckles' on out? or is it best to just swap the whole thing- ball joints, etc. will not line up? Any videos or tips on such a swap? I think I need a different booster, master cylinder and portioning valve. Any recommendations for that setup too? Thanks a lot.
02-07-2022, 10:41 AM | #2 | |
Re: 70 k10 front problems
02-15-2022, 05:45 PM | #3 |
Had the same problem. I tried replacing with a used one off of a spare rear that I have but had the same problem, the bearing did not have a tight / snug fit, luckily the aftermarket world has plenty, replaced with a new one, problem solved.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-16-2022, 10:03 AM | #4 |
[QUOTE=duallyjams;9035302]Had the same problem. I tried replacing with a used one off of a spare rear that I have but had the same problem, the bearing did not have a tight / snug fit, luckily the aftermarket world has plenty, replaced with a new one, problem solved.
thanks a lot- that spindle in the photo- it will fit a 1970 (drum) k10? where did you get it?! Scott |
02-16-2022, 10:09 AM | #5 | |
[quote=scottmitchellrose;9035534]
02-16-2022, 05:16 PM | #6 |
Scott---go to the 60-66 forum and the build section--search for 61k10 build. all the info toward the end (disc on the closed knuckle). New spindles from Yukon-hubs from Rockauto. they are big bearing spindles and hubs.
All the outer stuff of the 85 will be the big bearing stuff. It's all in my build--good luck Kimble
1961 chevy K10 my build is------------61K10 build |
03-03-2022, 04:29 AM | #7 |
RuffStuff has small and big bearing spindles for the Dana 44.
Big bearing https://www.ruffstuffspecialties.com/R2590.html Small bearing https://www.ruffstuffspecialties.com/r2573.html
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
