1969 k10 4 Speed to Automatic swap Brake Pedal
I am going to be collecting parts this year to convert my K10 from a SM465 to a 4L80E. Regarding the brake pedal assembly, is an Automatic brake pedal assembly the same as a Manual with the clutch pedal removed? Or should I replace the whole assembly? I've never seen an automatic one up close to notice the differences.
All about them K’s
![]() Join Date: Jun 2014
Re: 1969 k10 4 Speed to Automatic swap Brake Pedal
Same pedal assembly between auto and manual. The clutch pedal just slides in or out of the assembly.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Aug 2019
Your going to need the plate that covers the clutch rod hole. I have one.
How did this drivetrain swap work out?
ii have a 72 K10 4sp and wish to convert. did you do all the math and was it all worth it? is the truck better/easier to drive? Not so much worried about gas mileage, but curious as to driveability. Ideas? |
Can you post a picture? I'm converting mine to an auto right now and I've just zip tied the clutch pedal out of the way for now, but I do wish to move it when I convert to power brakes. As I tried to remove it already but it gets cought uo, so I'll have to remove the whole assembly inside.
#6 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 07-29-2023 at 12:34 AM. |
