02-12-2022, 01:58 PM | #1 |
Nicely done '61 Apache
Hard to improve on this one, great factory color ( Tampico Turquiose Poly). Only 3 items I would have done differently, bed wood, mirror head and tires would be done in black. Not mine. https://vmp.ebay.com/ebay/viewAllPho...?smid=48678524
02-12-2022, 08:32 PM | #2 |
Re: Nicely done '61 Apache
Add the interior to the list . Dark gray , silver AND FAWN ? Then the black firewall .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
02-13-2022, 01:22 AM | #3 |
I like it! Did anyone else notice the mismatched hubcap on one of the wheels? It's got a radio delete and cigarette lighter delete
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-13-2022, 10:11 AM | #4 |
Yeah it's a dealer sale. Little things could improve it a lot. Seat frame could have been painted, heater selectors repaired, master cylinder painted and so on.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-13-2022, 01:35 PM | #5 |
the only thing I would change is the name on the pink slip !!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
02-13-2022, 03:35 PM | #6 |
This is a frame on paint job did you get a glimpse of all the dirt and grease under the paint on the oil pan. This is a seller the guy that buys this truck won’t notice the hubcaps
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
02-26-2022, 11:05 PM | #7 |
1961 crewcab
very nice I wouldn't mind having it,, As factorystock mentioned I do like a solid black (stock) bed-- I would at least turn the mirror head a 1/4 turn, I assume you can't get a repro floor mat anymore , so the carpet gets a pass,, but the aftermarket choke knob , and turn and gearshift lever would need to be changed to stock--I don't mind the white walls , but I agree a truck would most likely have black walls....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-26-2022, 11:15 PM | #8 |
You can get a 64-66 repop, but since that also fits in the 60-63 cabs, I haven't seen a correct repop for 60-63. Sure does make me sad as my truck could use a new mat but I really don't want carpet. Maybe one day someone will repop it?
